13 years ago
Using sensitivity list for always block
Hello, I am just having a small confusion regarding best usages of sensitivity list. I understand that for combinational logic synthesis, all the signals should be included in the list (always @ (*)). However, is it a bad practice (or bad for synthesis) to have the always block be sensitive to posedge of some signal other than clk or rst ? Just an example...
always @ (posedge clk, posedge somesignal) begin
end
or
always @ (posedge somesignal) begin
end
thanks!
    yes it is. You are essentially making a new clock out of logic, and thats not a good idea, as it can cause timing problems. Just stick with a single clock and use clock enables:
    always @(posedge clk)
    if en = 1
    //do something
    There are applications for that, usually related to dealing with asynchronous signals. Ie, the following code toggles between "0" and "1" every time there's a rising edge om my_discriminator, which is useful to detect pulses shorter than one clock
    always @ (posedge my_discriminator_input)
    toggle <= !toggle;
    But that's the exception rather than the norm.
    If you have a signal generated by synchronous logic... then don't do that. It will just create complications.
    Hi rbugalho (http://www.alteraforum.com/forum/member.php?u=27812), yes, my signal is generated by synchronous logic. I had the intuition that it might not be a good idea and hence decided to do the following..
    always @ (posedge clk) begin
    if (mysignal == 1)
    //do stuff
    end
    I hope the above is fine. Can you please elaborate how it complicates the design ?
    Yes,the above is fine.
    The tools do not propagate clocks through registers, so you'll need to constrain each and every of those signals as a clock in order to get valid timing analysis.
    Also, in FPGAs the path from a logic cell to the flip-flops' clock port is very long -- it's a pre-built clock distribution tree. Any "clock" generated clock tends to have large skews in relation to other clocks and makes timing closure harder.
