12 years ago
Using PLL "lock" signal as the async reset in Verilog
If I want to use the PLL "lock' signal to work as an async reset, the "lock" signal will keep low after the FPGA is powered and goes high after a duration. If I won't reset my PLL, then it means "lock" siganl will never have a falling edge. If I power off the FPGA and power it again, it will have another rising edge.
In this case, can I still write the Verilog as following:
always @(posedge clk or negedge lock)
begin
if (lock == 1'b0)
else
end
As I mentioned previously, since there is no falling edge for "lock", will the Verilog code work? I guess it will but I am not sure.
Thanks in advance.
    --- Quote Start ---
    You do not want to use PLL lock as a reset signal directly. Not all PLL locked outputs have a debounce/deglitch filter, so they may toggle for a while before they stay in a static state.
    Download the code associated with this PCIe test
    http://www.alteraforum.com/forum/showthread.php?t=35678
    There's a deglitch/debounce filter in there you can use to "clean-up" the locked signal. You can then decide whether to use the "clean" signal as a synchronous or asynchronous reset signal.
    Cheers,
    Dave
    --- Quote End ---
    Hi Dave,
    First of all I hope you don't mind about my english, it's not my mother language. I'd like to know why you set the locked filter time to 0.5ms (25000 cycles in 50MHz), since Cyclone IV DS indicates Tlock = 1ms I figured out it might be set to 50000. Can you tell me more about it?
    Thank's!
    Anderson
    --- Quote Start ---
    This is synthesizeable - it tells the compiler what the initial register state is in the download bit-stream.
    --- Quote End ---
    Would this be the 'initial' block?? Or is there something else?
    --- Quote Start ---
    --- Quote End ---
    Synthesis tools do not support initial blocks very consistently. If you want to have an FPGA power-up with a particular value in a register you can assign that value during the initialization of the signal. For example;
    logic [31:0] regA = 32'h12345678;
    signal regA : std_logic_vector(31 downto 0) := X"12345678";
    You can chose to override these values in the reset part of a clocked process.
    Cheers,
    Dave
