10 years agouse verilog module in vhdl and the test bench
I am trying to instantiating a verilog module in a vhdl design. There is no error shown after compile it but i can't get the corresponding result in the modelsim.
Does anyone can help me to check the code please? The verilog module is:module i2c ( CLOCK,
I2C_SCLK, //I2C CLOCK
I2C_SDAT, //I2C DATA
I2C_DATA, //DATA:
GO, //GO transfor
ENDS, //ENDS transfor
W_R, //W_R
ACK, //ACK
RESET,
//TEST
SD_COUNTER,
SDO
); and I declare the component in vhdl is : component i2c port(
CLOCK : in std_logic;
I2C_SCLK : out std_logic;
I2C_SDAT : inout std_logic;
I2C_DATA : in std_logic_vector(23 downto 0);
GO : in std_logic;
ENDS : out std_logic;
W_R : in std_logic;
ACK : out std_logic;
RESET : in std_logic;
-- TEST
SD_COUNTER : out std_logic_vector (5 downto 0);
SDO : out std_logic
end component; When I use the testbench to simulate the code, The counter doesn't work. I don't know whats happening... http://i.imgur.com/wuzwbxf.png Does anyone can help me?5 Replies
The GO control bit is active low.
plus - the reset is also active low.
Thank you for your reply! I didn't realize the reset is active low, thank you so much!
However, I have another question about the I2C.v, I know I shouldn't ask it in here... Why I2C_SDAT is in high impedance if SDO is '1'? Is that means I2C_SDAT can't transmit the data?
I search it on google already and there is the same question but I still don't understand... http://www.alteraforum.com/forum/showthread.php?t=20018 (http://www.alteraforum.com/forum/showthread.php?t=20018)wire I2C_SDAT = SDO?1'bz:0 ; - Altera_Forum
Thank you so much, the problem is solve and the counter is working. Thank you!
--- Quote Start --- Thank you for your reply! I didn't realize the reset is active low, thank you so much! However, I have another question about the I2C.v, I know I shouldn't ask it in here... Why I2C_SDAT is in high impedance if SDO is '1'? Is that means I2C_SDAT can't transmit the data?
I search it on google already and there is the same question but I still don't understand... http://www.alteraforum.com/forum/showthread.php?t=20018 --- Quote End --- Because the designer chose to do everything active low without naming his signals appropriately or documenting the fact in the comments. Thats the only reason I can think ofwire I2C_SDAT = SDO?1'bz:0 ;
