10 years agouse verilog module in vhdl and the test bench
I am trying to instantiating a verilog module in a vhdl design. There is no error shown after compile it but i can't get the corresponding result in the modelsim. Does anyone can help me to che...
10 years ago --- Quote Start --- Thank you for your reply! I didn't realize the reset is active low, thank you so much! However, I have another question about the I2C.v, I know I shouldn't ask it in here... Why I2C_SDAT is in high impedance if SDO is '1'? Is that means I2C_SDAT can't transmit the data?
wire I2C_SDAT = SDO?1'bz:0 ; I search it on google already and there is the same question but I still don't understand... http://www.alteraforum.com/forum/showthread.php?t=20018 --- Quote End --- Because the designer chose to do everything active low without naming his signals appropriately or documenting the fact in the comments. Thats the only reason I can think of
