13 years ago
use of function lpm
Hi to everybody,
i write a small machine state to implement the and product separately..
i use std_logic_vector signal, so in the first state i sum the result of the product state.. but i never use lpm function so
i don't know how to istantiate these?
i try to do this but the compiler don't accept it..
I want that my program make product a*y and b*x in the state prodotto and the sum Y=pnum+pden in the second state
i post my code..
LIBRARY lpm;
USE lpm.lpm_components.ALL;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
USE ieee.std_logic_unsigned.ALL;
ENTITY add_sum IS
GENERIC (W1: integer:= 11; -- Input bit width
PORT (CLK : IN STD_logic;
x_in : IN STD_LOGIC_VECTOR(W1-1 DOWNTO 0);
y_out : OUT STD_LOGIC_VECTOR(W1-1 DOWNTO 0);
END add_sum;
ARCHITECTURE flex OF add_sum IS
SUBTYPE N1BIT IS STD_LOGIC_VECTOR(W1-1 DOWNTO 0);
TYPE state_type is (somma,prodotto);
SIGNAL stato: state_type :=prodotto;
SIGNAL x : N1BIT;
SIGNAL y : N1BIT;
myprocess: PROCESS
BEGIN
if (rising_edge(clk)) then
case state is
when somma => y<=pnum+pden;
stato<=prodotto;
when prodotto =>
lpm_mult_ist1: lpm_mult
PORT MAP (clock=>clk, dataa=>x, datab=>b, result =>pnum);
lpm_mult_ist2: lpm_mult
PORT MAP ( clock=>clk, dataa=>a, datab=>y, result =>pden);
stato<=somma;
end case;
end if;
end process myprocess;
y_out<=y;
END flex;
Thank for our response and attention!
by enrico
    You cant do a port map inside a process. entities have to be instantiated outside a process. components are not functions, they are like chips on a circuit board - so you cannot just add them when you want them.
    But you dont need lpm mult. If you ditch the non-standard libraries (std_logic_unsigned and std_logic_arith) and use numeric_std instead, you can simply write:
    pmum <= x * b;
    pden <= y *a;
    assuming x,y,a and b are declared signed/unsigned instead of std_logic_vector.
    --- Quote Start ---
    pmum <= x * b;
    pden <= y *a;
    --- Quote End ---
    thank you,
    but i must use std_logic... so.. is there possibility to change the signal pnum e pden that is the result of moltiplication?
    if i pass the values a,b,x,y when the program go out of the process.. and i use the component like i post here...
    SIGNAL x : N1BIT;
    SIGNAL y : N1BIT;
    SIGNAL pnum : N1BIT; -- PRODUCT ARRAY numerator
    SIGNAL pden : N1BIT; -- PRODUCT ARRAY denumerat
    constant b : std_logic_VECTOR(W1-1 DOWNTO 0) := "00000000001";
    constant a : std_logic_VECTOR(W1-1 DOWNTO 0) := "00000000010";
    BEGIN
    sop: PROCESS (clk)
    BEGIN
    case stato is
    when somma =>
    y<= pnum+pden;
    stato<=prodotto;
    when prodotto =>
    -- lpm_mult_ist1: lpm_mult(clock=>clk, dataa=>x, datab=>b, result =>pnum);
    -- lpm_mult_ist2: lpm_mult(clock=>clk, dataa=>y, datab=>a, result =>pden);
    stato<=somma;
    end case;
    end if;
    end process SOP;
    MulGen: FOR I IN 0 TO 1 GENERATE
    mymult1: lpm_mult --Moltiplicazione pnum(i)=c(i)*x
    GENERIC MAP (LPM_WIDTHA => W1, LPM_WIDTHB => W1,
    LPM_PIPELINE=>1,
    LPM_REPRESENTATION=>"SIGNED",
    LPM_WIDTHP =>W1,
    LPM_WIDTHS =>W1)
    END GENERATE;
    -- ISTANTIATE L PIPELINED MULTIPLIER DENUM
    MulGen2: FOR K IN 0 TO 1 generate --Moltiplicazione pden(i)=a(i)*y(i))
    mymult2: lpm_mult
    generic MAP (LPM_WIDTHA => W1,
    LPM_WIDTHB => W1,
    LPM_PIPELINE=>1,
    LPM_WIDTHP =>W1,
    LPM_WIDTHS =>W1)
    END generate;
    END FLEX;
    why are you now using a generate loop? you're trying to create 4 multipliers.
    --- Quote Start ---
    --- Quote End ---
    I haven't use a component before.. so i see an example in a book that use lpm.lpmmult to multiplie std_logic_vector.. so my input is std_logic_vector so i use this (component?! i think that generate.. generate components? is it ok?)
    so can you tell me how can multiply two std_logic_vector without this lpm.lpm_mult..
    with signed or unsigned there isn't this problem... so I wouldn't have written..
    my input must be std_logic_vector and my outoput too.
    So i haven't the knoledge of a designer of fpga because i'm only a student.. but if you want help me tell me how can resolve my problem..
    I must realiza a state machine
    in the first state(prodotto) i must do this operation pden=a*y and pnum=b*x, where a e b are costants of std_logic vector and x an input of std_logic_vector
    in the second state (somma) i must sum these y= pden+pnum...
    So.. the multipliers are only two...!
    I think that there is a possibility to pass argoment to a component out of the process and use this at the second moment (second clock) in my process.
    If you have same ideas.. thank!:o
    by enrico
    you can convert std_logic_vector into signed or unsigned:
    my_us <= unsigned(my_input)
    but you could just declare my_input as unsigned in the first place (it means you have less type conversion)
    but if you really insist on keeping std_logic_vector:
    op <= std_logic_vector(unsigned(a) * unsigned(b) );
    the same for signed.
    std_logic_vector, signed and unsigned are basically all of the same type - an array of bits. But the numeric_std package defines arithmatic functions for signed and unsigned.
    I highly suggest you look for a VHDL tutorial. Altera provides them for free:
    http://www.altera.co.uk/education/training/courses/ohdl1110
