--- Quote Start ---
You cant do a port map inside a process. entities have to be instantiated outside a process. components are not functions, they are like chips on a circuit board - so you cannot just add them when you want them.
But you dont need lpm mult. If you ditch the non-standard libraries (std_logic_unsigned and std_logic_arith) and use numeric_std instead, you can simply write:
pmum <= x * b;
pden <= y *a;
assuming x,y,a and b are declared signed/unsigned instead of std_logic_vector.
--- Quote End ---
thank you,
but i must use std_logic... so.. is there possibility to change the signal pnum e pden that is the result of moltiplication?
if i pass the values a,b,x,y when the program go out of the process.. and i use the component like i post here...
ARCHITECTURE flex OF add_sum IS
SUBTYPE N1BIT IS STD_LOGIC_VECTOR(W1-1 DOWNTO 0);
TYPE state_type is (somma,prodotto);
SIGNAL stato: state_type :=prodotto;
SIGNAL x : N1BIT;
SIGNAL y : N1BIT;
SIGNAL pnum : N1BIT; -- PRODUCT ARRAY numerator
SIGNAL pden : N1BIT; -- PRODUCT ARRAY denumerat
constant b : std_logic_VECTOR(W1-1 DOWNTO 0) := "00000000001";
constant a : std_logic_VECTOR(W1-1 DOWNTO 0) := "00000000010";
BEGIN
sop: PROCESS (clk)
BEGIN
if (rising_edge(clk)) then
case stato is
when somma =>
y<= pnum+pden;
stato<=prodotto;
when prodotto =>
-- lpm_mult_ist1: lpm_mult(clock=>clk, dataa=>x, datab=>b, result =>pnum);
-- lpm_mult_ist2: lpm_mult(clock=>clk, dataa=>y, datab=>a, result =>pden);
stato<=somma;
end case;
end if;
end process SOP;
MulGen: FOR I IN 0 TO 1 GENERATE
mymult1: lpm_mult --Moltiplicazione pnum(i)=c(i)*x
GENERIC MAP (LPM_WIDTHA => W1, LPM_WIDTHB => W1,
LPM_PIPELINE=>1,
LPM_REPRESENTATION=>"SIGNED",
LPM_WIDTHP =>W1,
LPM_WIDTHS =>W1)
PORT MAP (clock=>clk, dataa=>x, datab=>b, result =>pnum);
END GENERATE;
-- ISTANTIATE L PIPELINED MULTIPLIER DENUM
MulGen2: FOR K IN 0 TO 1 generate --Moltiplicazione pden(i)=a(i)*y(i))
mymult2: lpm_mult
generic MAP (LPM_WIDTHA => W1,
LPM_WIDTHB => W1,
LPM_PIPELINE=>1,
LPM_WIDTHP =>W1,
LPM_WIDTHS =>W1)
PORT MAP ( clock=>clk, dataa=>a, datab=>y, result =>pden);
END generate;
END FLEX;
