USB-Blaster not detected by Quartus 23.1
1 - install quartus prime lite 23.1 - OK
2 - install USB-blaster driver - OK (apear Altera USB-Blaster working properly on device manager)
But, when I click "Tools->Programmer->Hardware Setup-> Current selected hardware" the usb-blaster don't apear to be selected (but it's ok on device manager).
I've done this sequence using Windows 11 22H2 and Windows 10 22H2, and I have the same problem.
Whai is missing/ problem?
Thank you.
- sstrell
Dumb question: are you saying that the usb blaster doesn't appear in the pop-up list to select the hardware in "Currently selected hardware"?
And what does it look like in Device Manager? Maybe the driver needs to be reinstalled.
- IvanCaetano
In Device Manager, it's ok, driver installed and named "Altera USB-Blaster". But it doesn't appear in the pop-up list ("Currently selected hardware").
I've reinstalled the driver (many times) and even tried one for win7 (suggestion of another forum).
Is there any step after driver installation or just "see" it in the Quartus'Hardware Setup?
- NurAiman_M_Intel
Kindly refer to KDB below and let me know how it goes:
https://www.intel.com/content/www/us/en/support/programmable/articles/000073673.html
Another option to test, can you used another USB Blaster on the same system? Does the USB blaster appear?
Aiman
- IvanCaetano
Hi NurAiman_M_Intel.
I followed the stpes to disable “Altera JTAG Server”, but the USB-Blaster is not being detected by quartus yet. (done in 2 different laptops)
I bought another USB-Blaster today and I'll test it tomorrow.
Thank you.
- sstrell
Did you install the driver when you installed Quartus? You may need the USB Blaster II driver (instead of just USB Blaster).
- IvanCaetano
I installed the driver by:
"update driver in de Device Manager -> path "intelFPGA_lite\23.1std\quartus\drivers" -> selected checkbox "include subfolders" -> windows select the best driver in this path and install it.
I'm using a USB-Blaster like this.
- sstrell
That's a third-party clone of a USB Blaster that, as a number of reviews state, is garbage.
- NurAiman_M_Intel
- ARG007
Hi, I am facing the same issue of not detecting the USB Blaster in Quartus Prime lite. I did all the necessary steps mentioned in the previous thread but still the driver its not getting available in hardware setup. Can you please guide me in this regard??
