IvanCaetano
2 years agoUSB-Blaster not detected by Quartus 23.1
Hi, 1 - install quartus prime lite 23.1 - OK 2 - install USB-blaster driver - OK (apear Altera USB-Blaster working properly on device manager) But, when I click "Tools->Programmer->Hardware Setup-...
sstrell
2 years agoDid you install the driver when you installed Quartus? You may need the USB Blaster II driver (instead of just USB Blaster).
- IvanCaetano2 years ago
I installed the driver by:
"update driver in de Device Manager -> path "intelFPGA_lite\23.1std\quartus\drivers" -> selected checkbox "include subfolders" -> windows select the best driver in this path and install it.
I'm using a USB-Blaster like this.
- sstrell2 years ago
That's a third-party clone of a USB Blaster that, as a number of reviews state, is garbage.
Solved.
I've just tested another USB-Blaster and it's working on Windows 10. On Win11 the problem persists, as expected.
Could you point me a USB-Blaster good but not too expensive as original intel USB-Blaster?
Thank you everyone for your support.
