USB-Blaster not detected by Quartus 23.1
Did you install the driver when you installed Quartus? You may need the USB Blaster II driver (instead of just USB Blaster).
I installed the driver by:
"update driver in de Device Manager -> path "intelFPGA_lite\23.1std\quartus\drivers" -> selected checkbox "include subfolders" -> windows select the best driver in this path and install it.
I'm using a USB-Blaster like this.
- sstrell2 years ago
That's a third-party clone of a USB Blaster that, as a number of reviews state, is garbage.
- IvanCaetano2 years ago
Solved.
I've just tested another USB-Blaster and it's working on Windows 10. On Win11 the problem persists, as expected.
Could you point me a USB-Blaster good but not too expensive as original intel USB-Blaster?
Thank you everyone for your support.
- ARG0071 year ago
Hi, I am facing the same issue of not detecting the USB Blaster in Quartus Prime lite. The driver is visible in control device manager but in hardware setup its not getting available. Can you please guide me in this regard??
