Update memory initialization file in Quartus project for remote system update
I have implemented remote update on cyclone IV FPGA board. After the power cycle the factory image is configured and then the nios boots correctly. When I configure the application image without the application hex file, the sof is configured properly. I checked it by using PIO in Qsys and assigning different values to the fpga pins. In the factory configuration the fpga pin has 3 volts and in the application image it has 0 volts. I was also able to download elf file on the application image from eclipse.
- SyafieqS
Hi Fazeel,
Can you try double confirming and ensure that you have a valid .mif or .hex to process. Recheck and specify the location, including the file name and extension as well and try to reboot.
- aya1
Thank you Syafieq
Do I need to give the path in the parameter window of on chip memory in Qsys?
By doing this I initialise the on chip memory. Is there a way to initialise the epcs bootloader with my own custom bootloader?
- aya1
> "Recheck and specify the location, including the file name and extension as well and try to reboot."
by reboot you mean power cycling nios ??
