aya1
6 years agoUpdate memory initialization file in Quartus project for remote system update
I have implemented remote update on cyclone IV FPGA board. After the power cycle the factory image is configured and then the nios boots correctly. When I configure the application image without the ...
SyafieqS
6 years agoHi Fazeel,
Can you try double confirming and ensure that you have a valid .mif or .hex to process. Recheck and specify the location, including the file name and extension as well and try to reboot.
- aya16 years ago
Thank you Syafieq
Do I need to give the path in the parameter window of on chip memory in Qsys?
By doing this I initialise the on chip memory. Is there a way to initialise the epcs bootloader with my own custom bootloader?
- aya16 years ago
> "Recheck and specify the location, including the file name and extension as well and try to reboot."
by reboot you mean power cycling nios ??
