ma9647_kura387's avatar
ma9647_kura387
3 years ago
Uninstalling Quartus2
Quartus2 Web Edition の上位バージョンを使用するためにQuartus2 をアンインストールしたところ、「Windows-uninstall.exe が検出されません」というメッセージが表示され実行できなくなりました。
対処法を教えてください
  • May I know if above solution helped?
    Nurina
  • Nurina's avatar
    Nurina
    Nurina
    • ma9647_kura387's avatar
      ma9647_kura387
      As a result of executing all the uninstall files, V14.1 was able to be completely erased.
      Thank you for your kind response.
      Matchy
      ma9647_kura387
      Your solution was the best answer and very helpful.
      Thank you very much,
      Matchy
  • Nurina's avatar
    Nurina
    May I know which version of Quartus II you installed and which OS you are using?
    Nurina
      ma9647_kura387
      Quartus II version is 14.1 and ModelSim is 10.3c. The OS I'm using is Windows 10.
      matchy
  • sstrell's avatar
    sstrell
    There should be an uninstall directory in the quartus installation directory. Have you manually run the uninstaller there?
      ma9647_kura387
      I have not run the uninstaller.
      I try to run the application file "quartus_web-14.1.0.186-windows-uninstall" and others in the file folder "uninstall"
      Thank you for contact
      matchy
  • Nurina's avatar
    Nurina
    Hi Matchy,
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Feel free to open a new thread or login to ‘ https://supporttickets.intel.com ’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    If any answer from the community or Intel Support are helpful, feel free to rank your support experience by rating 4/5 survey. Please let me know of any inconvenience so that I may improve your future service experience.
    Have a great day!
    Nurina W.
