UserID4331231
1 year agounderstanding Hex file creation
In my FPGA project I have couple of memory which I plan on using as Configuration memory and general purpose memory. In Platform designer I made my project and I intend to assign them some initial va...
sstrell
1 year agoNo it means there's a mismatch between the RAM(s) you've created and the .hex files. How did you create the RAM? As IP or through HDL inference? What options did you choose?
- UserID43312311 year ago
- In platform designer - in IP catalog - i chose "On chip memory II (RAM or ROM) IP". I entered S1 port width, and entered size of memory in decimal (1024 for 1K instance and 1048756 for 1M instance). I chose hex file i wanted to chose for initialization.
- Once entire project is made in platform designer I click on generate HDL , closed platform designer and synthesised project in quartus.
the Hex file was created with quartus gui
- I clicked on files - and in new file wizard chose "hexadecimal (intel-format) file".
- Gui asks for word size and number of words. I chose values as described above. I select cell - right click and chose "Custom Fill Cells". I chose options to get desired auto incrementing pattern.
