Bharadwaja
1 year agoUnable to perform Dynamic Reconfiguration on Agilex I Series Device AGIB027R29A1E2VR0
I wanted to verify the dynamic reconfiguration on Agilex I Series Device AGIB027R29A1E2VR0. I generated an example from F Tile Dynamic Reconfiguration IP with the following settings. Once I ge...
Ash_R_Altera
1 year agoHi,
The example design by default has no loopback mode enabled. You will need and external QSFP-DD to test the design.
For internal loopback mode, QSFP-DD is NOT required.
The log messages in the TCL console window should indicate the rate at which the lanes are running after reconfiguration.
