Tex's avatar
Tex
3 years ago
UART receiver loopback characters VHDL
Greetings,
I'm new to the world of FPGA's
could anyone suggest me anything that helps me to learn implementing UART serial communication receiver loopback characters without state machines in VHDL
Tex
  • FvM's avatar
    FvM
    please elaborate your question. UART receiver implementation in VHDL is more or less clear, how is it specifically related to loopback?
    What's your problem with state machines?
  • Tex's avatar
    Tex
    Thanks for your reply,
    I'm a student, I would like to learn UART with fpga in VHDL
    loopback what i mean is, if i enter in the keyboard any character it should display in the serial monitor
    i'm thinking state machines are tough to learn
    please help me with any kind of tutorials where i can learn it or any codes
    best regards,
    Tex
  • Tex's avatar
    Tex
    Thanks for your valuable reply that's very help full tutorial for receiving
    I'm trying to achieve whatever the character i press in the keyboard it should receive in the serial monitor
    could you please help me
    Tex
  • ShengN_altera's avatar
    ShengN_altera
    Hi Tex,
    You may check on this first example design link:
    https://github.com/Domipheus/UART
    https://domipheus.com/blog/a-uart-implementation-in-vhdl/
    Make appropriate connection between O_tx and I_rx to form a loopback. The simulation result like below:
    This is second example design link (apparently state machine):
    https://nandland.com/project-7-uart-part-1-receive-data-from-computer/
    https://www.edaplayground.com/x/7Em
    https://www.edaplayground.com/x/5vEh
    https://nandland.com/7-segment-display/
    Make appropriate connection between o_TX_Serial and i_RX_Serial to form a loopback. The simulation result like below:
    Sheng
    • Tex's avatar
      Tex
      in test bench it is working
    • Tex's avatar
      Tex
      Thank you sheng this helped me alot..
      for the link 1
      when i try to assain pins there are showing more than 50
      please tell me which pins should i assaign only 3 enough ???
      regards,
      Tex
        ShengN_altera
        Hi Tex,
        Pins that should be assgined:
        I_clk
        I_reset
        I_txData (If you're getting the data externally from the board, then needed. Otherwise, not needed)
        O_tx, I_rx (Needed as to make loopback connection)
        O_rxData (If you're showing the received data externally to the board like LED or Monitor, then needed. Otherwise, not needed)
        For this I_txSig, you can comment out this input port and the rest in the code if you're not using it.
        For I_rxCont and I_clk_baud_count, you can declare them as signal instead of input port so that not need to make any pin assignment. For example like below:
        signal I_clk_baud_count : STD_LOGIC_VECTOR(15 downto 0) := X"01B2"; -- 115200bps @ 50Mhz Clk
        signal I_rxCont : STD_LOGIC := '1';
        Pins that not needed to be assigned (monitor and debug purpose):
        If you want to assign, you can assign to for example like LED respectively.
        O_txRdy
        O_rxSig
        O_rxFrameError
        D_rxClk
        D_rxState
        D_txClk
        D_txState
        Sheng
    ShengN_altera
    Hi Tex,
    Do you need any further help on this thread?
    Sheng
  • Tex's avatar
    Tex
    thanks for the help
    no more questions regarding this thread
    thank you
    regards
    Tex
