15 years ago
Two usb-blasters with one PC?
Have someone tried to use two USB-blasters with one PC at same time?
If you can, do you need to open two Quartus II?
I'd like to know it because I will use transceiver tool kit for two boards back to back.
    --- Quote Start ---
    It's apparently different with Terasic, i'll check occasionly. I guess, they did it because Quartus requests a driver installation every time a device with a new ID is plugged for the first time. So you have to edit the IDs with the FTDI tool if you want to connect more than one simultaneously.
    --- Quote End ---
    I don't know if you have succeed on this. I made it long time ago, and it's quite easy with FTDI tool to rewrite FT245 external eeprom.
    Search for FT_PROG tool in FTDI website.
