15 years ago --- Quote Start --- It's apparently different with Terasic, i'll check occasionly. I guess, they did it because Quartus requests a driver installation every time a device with a new ID is plugged for the first time. So you have to edit the IDs with the FTDI tool if you want to connect more than one simultaneously. --- Quote End --- I don't know if you have succeed on this. I made it long time ago, and it's quite easy with FTDI tool to rewrite FT245 external eeprom. Search for FT_PROG tool in FTDI website.
