Altera_ForumHonored Contributor15 years agoTwo usb-blasters with one PC? Hi, Have someone tried to use two USB-blasters with one PC at same time? If you can, do you need to open two Quartus II? I'd like to know it because I will use transceiver tool kit for t...Show More
Recent DiscussionsDuplicate_hierarchy_depth / duplicate_registerUnable to download Quartushow to reduce clock skew between synchronous clockQuartusPro 25.3 Crashed after using the Signal Tap Logic AnalyzerTiming analysis - long combinational path
