12 years ago
Transmission with DE2-70 and the daughter board THDB-ADA
Hi !
I'm currently working with DE2-70 and the daughter board THBD-ADA. I have to send a sinus wave (in digital) from the board to the DAC converter, then to the ADC converter, and get it back, to study this transmission. For being able to see the signals, i'm using SignalTap, but i don't know if my signals are sent or not received...
This is my code :
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all; -- WARP : use work.std_arith.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_signed.all;
use ieee.numeric_std.all;
ENTITY Coucou Is
PORT( iCLK_50 : IN std_logic; -- Horloge de 50 MHz
-- Entrees/Sorties
DAC_DA, DAC_DB : OUT std_logic_vector(13 downto 0); -- D-A
ADC_DA, ADC_DB : IN std_logic_vector(13 downto 0);	 -- A-D
-- Setup ADC and DAC
DAC_MODE : OUT std_logic; -- DAC mode, 1 for dual, 0 for interleaved
DAC_WRTA : OUT std_logic; -- Write signal Channel A
DAC_WRTB : OUT std_logic; -- Write signal Channel B
ADC_OEA : OUT std_logic; -- Channel A enable
ADC_OEB : OUT std_logic; -- Channel b enable
PLL_OUT_ADC0, PLL_OUT_ADC1 : OUT std_logic;
PLL_OUT_DAC0, PLL_OUT_DAC1 : OUT std_logic); -- Clock from GPIO
END Coucou;
ARCHITECTURE Archi_Coucou OF Coucou IS
TYPE VAL_FUNCTION IS ARRAY (0 TO 49) OF INTEGER; -- tableau de 50 entiers
SIGNAL Sinus : VAL_FUNCTION;
SIGNAL a : INTEGER;
SIGNAL clockF, clockR : std_logic;
BEGIN
--Create signal------------------------------
Sinus <= (0 => 0, 1 => 1027, 2 => 2037, 3 => 3016, 4 => 3947,
5 => 4815, 6 => 5608, 7 => 6312, 8 => 6917, 9 => 7412,
10 => 7791, 11 => 8047, 12 => 8176, 13 => 8176, 14 => 8047,	 -- 50 points per periode
15 => 7791, 16 => 7412, 17 => 6917, 18 => 6312, 19 => 5608,
20 => 4815, 21 => 3947, 22 => 3016, 23 => 2037, 24 => 1027,	 -- Frequency of 10 MHz
25 => 0, 26 => -1027, 27 => -2037, 28 => -3016, 29 => -3947,
30 => -4815, 31 => -5608, 32 => -6312, 33 => -6917, 34 => -7412,	 -- points calculated for 14-bit words
35 => -7791, 36 => -8047, 37 => -8176, 38 => -8176, 39 => -8047,
40 => -7791, 41 => -7412, 42 => -6917, 43 => -6312, 44 => -5608,
45 => -4815, 46 => -3947, 47 => -3016, 48 => -2037, 49 => -1027);
--Clock processing---------------------------
process(iCLK_50)
begin
if falling_edge(iCLK_50) then
clockF <= not(clockF);
end if;
if rising_edge(iCLK_50) then
clockR <= not(clockR);
end if;
end process;
--DAC and ADC interface----------------------
PLL_OUT_ADC0 <= clockR;
PLL_OUT_ADC1 <= clockR;
PLL_OUT_DAC0 <= clockF;
PLL_OUT_DAC1 <= clockF;
DAC_WRTA <= clockF;
DAC_WRTB <= clockF;
DAC_MODE <= '1'; -- Dual mode
ADC_OEA <= '0';
ADC_OEB <= '1';
-- Outputs
create_signal_process: process(clockR)
VARIABLE CLK_Count : INTEGER :=0;
begin
if rising_edge(clockR) then
IF (CLK_Count < 50) THEN
a <= Sinus (CLK_Count);
DAC_DB <= std_logic_vector(to_signed(a, 14)); -- Convert sinus into 14-bit word
CLK_Count := CLK_Count + 1;
ELSE
CLK_Count := 0;
END IF;
end if;
end process;
END Archi_Coucou;
Does somebody can help me ?
Thanks and scuse me for my approximative english ...
    What exactly is the problem? have you run this through a testbench?
    Did you realise that logic generated clocks are usually a bad idea?
    --- Quote Start ---
    --- Quote End ---
    I just load the program in the board (DE2-70), and I would like to get the signal after the loop, (board -> converter D-A -> converter A-D -> board). I'm not a pro of VHDL, and it's the first time I use SignalTap, and I never used a testbench :(
    You think it is better to use just iCLK_50 rather than ClockR and ClockF ? I tried this because it was a proposition in precedent posts ...
    Thanks for your help !
