Timing Violations: 8x F-Tile ETH Hard IP TX_CLKOUT
Hello Intel Team,
In our design, we instantiated eight 10G F-Tile Ethernet Hard IPs (including ANLT) using the VHDL "GENERATE" construct. During timing analysis, we are encountering setup and hold violations on the "TX_CLKOUT" path of the F-Tile transceivers.
The "REPORT_CLOCKS" command shows that these 8 clocks are being generated with a frequency of 402.83 MHz under the following names:
gen_eth[0].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch23
gen_eth[1].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch22
gen_eth[7].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch16
The corresponding master clocks are:
gen_eth[0].proc_ftile_eth_hardip|eth_f_0|tx_pld_pcs_clk_reg|ch23
TX_CLKOUT clocks are asynchronous to each other and operate independently. Therefore, we attempted to exclude them from timing analysis using the "set_clock_groups -asynchronous" constraint, like this:
set_clock_groups -asynchronous \
-group { [get_clocks {gen_eth[0].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch23}] } \
-group { [get_clocks {gen_eth[1].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch22}] } \
-group { [get_clocks {gen_eth[2].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch21}] } \
-group { [get_clocks {gen_eth[3].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch20}] } \
-group { [get_clocks {gen_eth[4].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch19}] } \
-group { [get_clocks {gen_eth[5].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch18}] } \
-group { [get_clocks {gen_eth[6].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch17}] } \
-group { [get_clocks {gen_eth[7].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch16}] }
However, this approach results in the following errors:
- Warning(20314): Invalid collection filter: [get_clocks {gen_eth[0].proc...}]
- Warning(332049): Ignored set_clocks_group: Argument -group with value could not match any element of the type clk.
- Warning(332049): Argument -group is not an obejct ID.
I’ve tried multiple approaches, get_nets, Get_pins, also using wildcards and "create_generated_clock", but nothing has resolved the issue.
According to my understanding, a "create_generated_clock" constraint shouldn't be necessary, since these clocks are automatically generated by Quartus.
When inspecting the design in the Timing Analyzer using "get_clocks *ch23, the clock names appear to be internally resolved to autogenerated IDs like "_co15660".
However, these IDs are not stable and may change with each compile (fit), which makes them unsuitable for constraints.
At this point, I am running out of ideas.
- Question:
How can I properly constraint or eliminate the setup and hold violations on the eight "TX_CLKout" clocks generated by Quartus in the F-Tile Ethernet Hard IPs? - Should I just use "Set_False_Path"?
- I used the "Generate" command in VHDL to instantiate the 8 F-Tile ETH Hard IP + 8 ANLT. Could be this a problem ?
kind regards
Jacob
- JackDalton
is the problem perhaps too obvious ?
The F-Tile manual couldn't give me any clues.
What have I missed?
I would appreciate a quick hint.
I would also like to add that we are using the Agilex 7 i-series with Quartus 25.1.
kind regards
Jack
- paveetirrasrie_Altera
- Run report_clocks in the Timing Analyzer GUI.
- Identify the actual clock names for your 8 TX_CLKOUT clocks.
- Update your SDC to use the internal names (e.g., _co15660, etc.) in your set_clock_groups constraint.
- Re-run Timing Analysis.
- The violations should be gone for cross-domain paths.
- If you want a more robust SDC that survives name changes, use wildcards or regular expressions if possible, or group all relevant clocks at once:
- set_clock_groups -asynchronous -group [get_clocks *_tx_clkout*]
- No, the VHDL generate statement is not the problem as long as each instance is independent. The issue is the SDC matching, not your VHDL instantiation.
Hope this helps.
Pavee
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Thank you.
