timing violation fix
thank you for replay!
the main is setup violation with 416Mhz! there are 416Mhz and 208Mhz clock domain, some region is worked in the 208Mhz!
If the main issue is setup violation at 416 MHz, while part of the design already runs at 208 MHz, then the next step is to focus on the remaining critical paths in the 416 MHz domain and also confirm that the crossings between the 416 MHz and 208 MHz domains are constrained correctly.
A practical approach is:
- First verify the SDC constraints for the 416 MHz and 208 MHz clocks.
- If the clocks are related, keep normal timing analysis between them.
- If any crossings are functionally asynchronous, apply proper CDC handling and timing exceptions.
- Then group the failing setup paths into:
- 416 MHz to 416 MHz
- 416 MHz to 208 MHz
- 208 MHz to 416 MHz
- Prioritize the recurring 416 MHz to 416 MHz failures first, since these usually determine whether the design can meet 416 MHz.
- For the worst failing 416 MHz paths, check:
- logic depth
- routing delay
- high fan-out control signals
- RAM/DSP/FIFO boundaries
- reset or clock-enable impact
- For Agilex 7 specifically, also check whether Hyper-Retiming is being limited by:
- insufficient pipeline stages
- asynchronous resets
- wide broadcast clock enables
- FIFO full/empty style control feedback
- congestion or long-distance routing
- If some functions currently in the 416 MHz region do not need to run at full rate, moving them behind a registered interface into the 208 MHz region can help reduce setup pressure.
So in short, the recommendation is not only to add more pipeline stages, but also to classify the failing paths by clock relationship and then focus on the repeated 416 MHz path families first.
