18 years agotiming simulation in modelsim after quartus place and route
I wrote a simple RAM in deffernt versions. I get data and address and my output is the address and the data after place and route and running timing simulation (checked at least 10 different versions) I never get my signals synchronized to the clk (rising_edge) for example: entity sobel_ram_start_double_process is generic(add_width: integer:= 2;data_width: integer:= 4); port ( clk : in std_logic; wr_en : in std_logic; data_in : in std_logic_vector (data_width-1 downto 0); address : in std_logic_vector (add_width-1 downto 0); address_ram1 : out std_logic_vector (add_width-1 downto 0); data_out : out std_logic_vector (data_width-1 downto 0)); end entity; architecture sobel_ram_start_double_process_arch of sobel_ram_start_double_process is type mem is array (2**add_width-1 downto 0) of std_logic_vector(data_width-1 downto 0); signal array_data : mem; signal address_save : std_logic_vector(add_width-1 downto 0); begin getting_data:process(clk) begin if rising_edge(clk) then if wr_en='1' then array_data(conv_integer(address))<=data_in; end if; end if; end process; address_saving:process(clk) begin if rising_edge(clk) then if wr_en='1' then address_save<=address; address_ram1<=address_save; end if; end if; end process; end architecture; In modelsim it works perfect but after using *.vho and *.sdo I dont understand what the quartus does!!! address_ram1 gets a value without my initialization... instead of simple pipeline implementation the data is presented in strange way... I tried almost every version (2 process, 1 process, outside the process) and couldn't synchronize my signals (address_ram1 and the output) the the clk :-( even under the same wr_en I get the data with delay (and not the delta)... What should I do? Tenx ari
