17 years agohello,
I want to run an EDA gate level simulation to my VHDL design using QuartusII 6.1 and Altera Modelsim 6.1g but when i run the simulation I obtain this error: ** warning: (vsim-3473) component instance "soc : mapping_minimips" is not bound. # time: 0 ps iteration: 0 region: /test_mm file: d:/these/inria/fpga_2s180/vga/4pe_avecvga/avec_xnet_and_linear/test_mm.vhd # ** fatal: sdf files require altera primitive library # time: 0 ps iteration: 0 instance: /test_mm file: d:/these/inria/fpga_2s180/vga/4pe_avecvga/avec_xnet_and_linear/test_mm.vhd line: unknown # fatal error while loading design # error loading design # error: error loading design # pausing macro execution # macro ./standard_run_msim_gate_vhdl.do paused at line 12
Could you please help me, thanks in advance Mouna.
