IDeyn
Contributor
7 years agoTimeQuest strange behavior - seems like a bug in PLL output clock visualization
Hi all! Recently faced such problem - in the test project there are two PLLs, with input from two base input clocks. One clock is 50 MHz with waveform { 0.000 10.000 } and on also 50 MHz with wavef...
IDeyn
Contributor
7 years agoHi Abe ,
Thank you very much for your answer.
It can be a real design case, where clocks are shifted on board, so we need a way to describe it in TQ.
So, again it looks that derive_pll_clocks can't be used with input clocks with phase shift, in that case we need to manually write generated_clocks, which is inconvenient.
In my opinion, it is a bug and it will be good if it will be corrected.
Ivan
