CosmoKramer
3 years agoThe RTL netlist is not available error
I completed building fpga image. But when I tried to looking at timing path in rtl viewer, I get error that RTL netlist is not available.
I did not set this option - Aggressive Compile Time - as per this link:
https://www.intel.com/content/www/us/en/support/programmable/articles/000086719.html
how can I resolve this issue? Tool cant complete timing analysis without a netlist so it must be there.
- sstrell
So you performed a full compilation and you're getting an error that you can't view the design in the RTL Viewer?
If you manually just run synthesis instead of a full compilation, can you view the design in the RTL Viewer?
Is this Standard or Pro?
- ShengN_altera
Any further update or concern?
