The FIFO has no output waveform
Dear Richard,
Thank you for your guidance. Regarding the previous issue, the necessary settings were indeed related to the Testbench options.
Currently, I am directly using the generated .V (Verilog) file from the configured FIFO IP Core for simulation, rather than creating a separate Testbench file.
I would like to inquire about how to configure the Data Bus input in Questa – Intel FPGA Starter Edition to ensure that a new value is input at a fixed time interval (or fixed timing) for each clock cycle.
Thank you for your assistance.
Hi MartinMaa
To configure the data bus input in Questa, you will need a testbench file.
You can generate one using the Simulation Waveform Editor, or alternatively, you can use an AI tool to assist you with this.
For better understanding, we have a quick start guide for the Quartus Standard simulation flow, along with an example design that you can try out.
https://www.intel.com/content/www/us/en/docs/programmable/703090/21-1/open-the-example-design.html
p.s: The RTL Simulation feature in Quartus is also known as NativeLink Flow
https://www.intel.com/content/www/us/en/docs/programmable/683080/23-1/running-rtl-simulation-nativelink-flow.html
Richard Tan
