Hi sstrell,
Thanks, and No none That i can see. I will verify that though again in the fitter report and post synthesis! I think i see how to do it now...using the 'add state machine nodes...' menu item.
One other point: How do i add in a new trigger column ? I can't see hw to do that in Quartus Standard Edition version 25.1 If i right click for example on the existing trigger column, marked as 1, nothing in the popup menu here offers any way to add in anew Trigger Column. And none of the other menus do either as far as i can see./
Cheers, Dr Barry H
Settings on the right, set the number of trigger conditions.
- drbarryh16 days ago
Thanks sstrell, yes i see that now. And you can have advanced mode as well for triggers. That might be worth investigating. And adding in a Mnemonic text file to link to any State Machines will be useful too :)
cheers, Dr Barry H
