Quartus Pro 25.3 crash using rhel7/8
Hello everybody
I'm working on an Agilex-5 project since fex months on our internal couputer farm using Quartus Pro 25.3. To generate the final bitstream, a bash script is used to execute all the steps. Until now, we have no specific issue using this script with Quartus.
But since few days, we're unable to generate the project because Quartus Pro returns strange errors (see attachments). We also tried to use latest 23.5.1 version on an Ubuntu host under WSL and we also saw the same errors.
Running Quartus GUI may also end with same error. (see quartus_4.png)
Has anyone already experienced this issue?
Thanks a lot
Benjamin
Hi all,
The KDB link had been live check https://community.altera.com/kb/knowledge-base/why-do-i-unexpectedly-observe-intermittent-ddm-errors/349714
- roeekalinsky
Contributor
I too am seeing similar issues that seem to have cropped up out of nowhere in the past 48 hours.
Intermittent crashes of Quartus Pro (running in shell mode) occurring seemingly at random at varying stages of the flow, and also intermittent failures immediately upon launch of Quartus Pro (in shell mode) resulting in an identical error message and stack trace to those shown in the original poster's screen shot quartus_4.PNG.
I'm seeing this occur with multiple versions of Quartus Pro (24.2, 25.1, 25.3.1) running on several different machines and different operating systems (RHEL 8 and RHEL 9), all of which were working perfectly up until the past couple of days.
-Roee
- nskim
We confirm that we are experiencing the same crash issue with Quartus Pro 24.3 and 24.1 across multiple servers, all running Ubuntu 24.04. The issue began on the morning of January 10, 2026. We have verified that all licenses are valid; however, compilation consistently crashes with an unknown internal error. The same setup worked previously without any issues.
- torerams
I can confirm that I’m experiencing the same errors when running Quartus Pro 25.3 in Docker containers. Since Sunday (11/01/2026), none of my Quartus Pro 23.3 GUI installations have been working on either Windows 11 or Ubuntu 24.04. All of them hang when attempting to perform place-and-route (P&R) on a design. The same source code, scripts, and settings were working on Windows 11, Ubuntu 24.04, and Docker PCs on Saturday (10/01). I’m currently unable to perform P&R on any Quartus Pro design.
If anyone has a workaround for this issue, please share it here
- Dorton
We are also seeing a similar issue.
Error (22912): Unhandled exception:
Fatal Error: Assertion failed tools/cpp/ddm/ddm_assessor.cpp:53: DDM_T::verify_token(token) : Cannot identify the client
from function assertion_error in tools/cpp/ddm_report/ddm_report_msg.cpp@455
We use Quartus 24.2, and the problem seemed to appear on Saturday 10th of January 2026.
Sometimes the compilations get stuck at the synthesis stage, sometimes it works after retrying.
- torerams
Has anyone tested this by setting the PC date to before January 10, 2026?
I just tested this, and as expected it does not work. Quartus/flexlm detects date set back. - cblixt
All errors of this kind, starting to appear on Jan 10, are solved and patches are available at Why do I unexpectedly observe intermittent DDM Errors? | Altera Community
- SueC_Altera
Contributor
You can get the patch from this KDB:
- FvM
it's stated very clearly that all Quartus Pro versions >= 23.3 up to recent 25.3.1 need the patch.
You can install it for all used versions without wasting time by checking if the error occurs on your PC.- Milan_S
Yes, it looks the patch helps.
- bpussacq
I forgot to mention that we're using LSF8 for dispatching jobs on the computer farm.
- ShengN_altera
Internal message as below:
There was a Quartus Prime Pro issue broadly discovered by customers, field and internal teams in which the Quartus code that calculates the date and time from the DDM client ID mistakenly identifies the time being shifted an hour from the current time which in turn, causes a Quartus crash to take place. This issue began when the year turned to 2026 and we moved to a two-digit date in the month of January. This crash affects:
Quartus Prime Pro Software versions v23.3 through v25.3.1
Quartus Embedded Edition v25.3 and v25.3.1
Quartus Programmer v23.3 through v25.3.1
This issue can be seen when using Quartus software through command line or GUI interface.
Quartus Patch requests have been filed for the above software and tools. A KDB draft is available and will be reviewed and released when the patches are ready. These fixes and KDB are being driven with utmost priority.
Will get back once the patch and kdb are available.
- bpussacq
Hi
Thanks a lot to you and everybody for feedbacks.
Have a great day.
Best regards, Benjamin
- Tom_CN
We have also started seeing similar errors today. We have two PCs running Ubuntu 22.04.5 LTS (GNU/Linux 6.8.0-90-generic x86_64) and Quartus 24.1.
It does not crash consistently each time. Below are some of the errors:
Starting Quartus:
$ /opt/tools/altera/intelFPGA_pro/24.1/quartus/bin/quartus & Error (22912): Unhandled exception: Fatal Error: Assertion failed tools/cpp/ddm/ddm_assessor.cpp:53: DDM_T::verify_token(token) : Cannot identify the client from function assertion_error in tools/cpp/ddm_report/ddm_report_msg.cpp@455 *** Fatal Error: Program termination requested *** *** Below is the stack trace at the time the error occurred. *** The lines beginning "Err Handler" represent frames relating *** to generating this report. *** The point at which the error occurred is somewhere after these lines. *** There may be a few frames representing standard/library code *** before the Quartus frames begin. *** The search for the error should begin with the Quartus frames. *** Unwinder: libunwind *** Stack depth: 15 Quartus 0x22142: err_terminator() + 0x1a4 (ccl_err) Quartus 0xa916a: __cxxabiv1::__terminate(void (*)()) + 0xa (stdc++) Quartus 0xa91d5: (stdc++) Quartus 0xa9428: (stdc++) Quartus 0x154eb: void ddm_throw<DDM_RUNTIME_ERROR>(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x3bb (ddm_report) Quartus 0x12cf9: DDM_REPORT::DDM_ASSERTION_HANDLER::assertion_error(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >) const + 0xc9 (ddm_report) Quartus 0x11918: DDM_REPORT::ASSERTION_HANDLER::error(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >) + 0x68 (ddm_report) Quartus 0x12bd6: DDM_REPORT::detail::assert_at_line(char const*, char const*, int, char const*, ...) + 0x1b6 (ddm_report) Quartus 0x1ad479: ddm_set_lassessor(DDM_T_ASSESSOR*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x49 (ddm) Quartus 0xd2294: DMS_MANAGER::DMS_MANAGER() + 0x456 (dni_dms) Quartus 0xd23c4: DMS_MANAGER::get() + 0x7a (dni_dms) Quartus 0xd45be: _GLOBAL__sub_I_dms_manager.cpp + 0x7d (dni_dms) Quartus 0x647e: (ld-linux-x86-64) Quartus 0x6568: (ld-linux-x86-64) Quartus 0x202ca: (ld-linux-x86-64)During compilation:
Error: UNAVAILABLE: Network closed for unknown reason Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNAVAILABLE: io exception Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607 Error: UNKNOWN: Application error processing RPC Error: UNKNOWN: Application error processing RPC Error: UNKNOWN: Application error processing RPC Error: UNKNOWN: Application error processing RPC Error: UNKNOWN: Application error processing RPC Error: Quartus Prime IP Generation Tool was unsuccessful. 132 errors, 22 warnings Error: Peak virtual memory: 992 megabytes Error: Processing ended: Mon Jan 12 17:55:06 2026 Error: Elapsed time: 00:00:52 Error: System process ID: 1339331 Error(21794): Quartus Prime Full Compilation was unsuccessful. 134 errors, 22 warningsserv_req_info.txt:
<?xml version="1.0" encoding="utf-8"?> <internal_error> <sub_system>ERR</sub_system> <callstack>*** Fatal Error: 0x7f9e34172142: ccl_err + 0x22142 (_Z14err_terminatorv + 0x1a4) 0x7f9e2faa916a: stdc++ + 0xa916a (_ZN10__cxxabiv111__terminateEPFvvE + 0xa) 0x7f9e2faa91d5: stdc++ + 0xa91d5 0x7f9e2faa9428: stdc++ + 0xa9428 0x7f9e2f0924eb: ddm_report + 0x154eb (_Z9ddm_throwI17DDM_RUNTIME_ERROREvRKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE + 0x3bb) 0x7f9e2f08fcf9: ddm_report + 0x12cf9 (_ZNK10DDM_REPORT21DDM_ASSERTION_HANDLER15assertion_errorENSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE + 0xc9) 0x7f9e2f08e918: ddm_report + 0x11918 (_ZN10DDM_REPORT17ASSERTION_HANDLER5errorENSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE + 0x68) 0x7f9e2f08fbd6: ddm_report + 0x12bd6 (_ZN10DDM_REPORT6detail14assert_at_lineEPKcS2_iS2_z + 0x1b6) 0x7f9e1edad479: ddm + 0x1ad479 (_Z17ddm_set_lassessorP14DDM_T_ASSESSORRKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE + 0x49) 0x7f9e30545294: dni_dms + 0xd2294 (_ZN11DMS_MANAGERC1Ev + 0x456) 0x7f9e305453c4: dni_dms + 0xd23c4 (_ZN11DMS_MANAGER3getEv + 0x7a) 0x7f9e305475be: dni_dms + 0xd45be (_GLOBAL__sub_I_dms_manager.cpp + 0x7d) 0x7f9e35c9147e: ld-linux-x86-64 + 0x647e 0x7f9e35c91568: ld-linux-x86-64 + 0x6568 0x7f9e35cab2ca: ld-linux-x86-64 + 0x202ca </callstack> <error>Program termination requested</error> <date>Mon Jan 12 17:54:02 2026 </date> <version>Version 24.1.0 Build 115 03/21/2024 SC Pro Edition</version> </internal_error>
