bpussacq
8 months agoQuartus Pro 25.3 crash using rhel7/8
Hello everybody I'm working on an Agilex-5 project since fex months on our internal couputer farm using Quartus Pro 25.3. To generate the final bitstream, a bash script is used to execute all the st...
- 8 months ago
Hi all,
The KDB link had been live check https://community.altera.com/kb/knowledge-base/why-do-i-unexpectedly-observe-intermittent-ddm-errors/349714
Tom_CN
8 months agoHi,
We have also started seeing similar errors today. We have two PCs running Ubuntu 22.04.5 LTS (GNU/Linux 6.8.0-90-generic x86_64) and Quartus 24.1.
It does not crash consistently each time. Below are some of the errors:
Starting Quartus:
$ /opt/tools/altera/intelFPGA_pro/24.1/quartus/bin/quartus &
Error (22912): Unhandled exception:
Fatal Error: Assertion failed tools/cpp/ddm/ddm_assessor.cpp:53: DDM_T::verify_token(token) : Cannot identify the client
from function assertion_error in tools/cpp/ddm_report/ddm_report_msg.cpp@455
*** Fatal Error: Program termination requested
*** Below is the stack trace at the time the error occurred.
*** The lines beginning "Err Handler" represent frames relating
*** to generating this report.
*** The point at which the error occurred is somewhere after these lines.
*** There may be a few frames representing standard/library code
*** before the Quartus frames begin.
*** The search for the error should begin with the Quartus frames.
*** Unwinder: libunwind
*** Stack depth: 15
Quartus 0x22142: err_terminator() + 0x1a4 (ccl_err)
Quartus 0xa916a: __cxxabiv1::__terminate(void (*)()) + 0xa (stdc++)
Quartus 0xa91d5: (stdc++)
Quartus 0xa9428: (stdc++)
Quartus 0x154eb: void ddm_throw<DDM_RUNTIME_ERROR>(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x3bb (ddm_report)
Quartus 0x12cf9: DDM_REPORT::DDM_ASSERTION_HANDLER::assertion_error(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >) const + 0xc9 (ddm_report)
Quartus 0x11918: DDM_REPORT::ASSERTION_HANDLER::error(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >) + 0x68 (ddm_report)
Quartus 0x12bd6: DDM_REPORT::detail::assert_at_line(char const*, char const*, int, char const*, ...) + 0x1b6 (ddm_report)
Quartus 0x1ad479: ddm_set_lassessor(DDM_T_ASSESSOR*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x49 (ddm)
Quartus 0xd2294: DMS_MANAGER::DMS_MANAGER() + 0x456 (dni_dms)
Quartus 0xd23c4: DMS_MANAGER::get() + 0x7a (dni_dms)
Quartus 0xd45be: _GLOBAL__sub_I_dms_manager.cpp + 0x7d (dni_dms)
Quartus 0x647e: (ld-linux-x86-64)
Quartus 0x6568: (ld-linux-x86-64)
Quartus 0x202ca: (ld-linux-x86-64)
During compilation:
Error: UNAVAILABLE: Network closed for unknown reason
Error: UNAVAILABLE: io exception
Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607
Error: UNKNOWN: Application error processing RPC
Error: Quartus Prime IP Generation Tool was unsuccessful. 132 errors, 22 warnings
Error: Peak virtual memory: 992 megabytes
Error: Processing ended: Mon Jan 12 17:55:06 2026
Error: Elapsed time: 00:00:52
Error: System process ID: 1339331
Error(21794): Quartus Prime Full Compilation was unsuccessful. 134 errors, 22 warnings
serv_req_info.txt:
<?xml version="1.0" encoding="utf-8"?>
<internal_error>
<sub_system>ERR</sub_system>
<callstack>*** Fatal Error: 0x7f9e34172142: ccl_err + 0x22142 (_Z14err_terminatorv + 0x1a4)
0x7f9e2faa916a: stdc++ + 0xa916a (_ZN10__cxxabiv111__terminateEPFvvE + 0xa)
0x7f9e2faa91d5: stdc++ + 0xa91d5
0x7f9e2faa9428: stdc++ + 0xa9428
0x7f9e2f0924eb: ddm_report + 0x154eb (_Z9ddm_throwI17DDM_RUNTIME_ERROREvRKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE + 0x3bb)
0x7f9e2f08fcf9: ddm_report + 0x12cf9 (_ZNK10DDM_REPORT21DDM_ASSERTION_HANDLER15assertion_errorENSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE + 0xc9)
0x7f9e2f08e918: ddm_report + 0x11918 (_ZN10DDM_REPORT17ASSERTION_HANDLER5errorENSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE + 0x68)
0x7f9e2f08fbd6: ddm_report + 0x12bd6 (_ZN10DDM_REPORT6detail14assert_at_lineEPKcS2_iS2_z + 0x1b6)
0x7f9e1edad479: ddm + 0x1ad479 (_Z17ddm_set_lassessorP14DDM_T_ASSESSORRKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE + 0x49)
0x7f9e30545294: dni_dms + 0xd2294 (_ZN11DMS_MANAGERC1Ev + 0x456)
0x7f9e305453c4: dni_dms + 0xd23c4 (_ZN11DMS_MANAGER3getEv + 0x7a)
0x7f9e305475be: dni_dms + 0xd45be (_GLOBAL__sub_I_dms_manager.cpp + 0x7d)
0x7f9e35c9147e: ld-linux-x86-64 + 0x647e
0x7f9e35c91568: ld-linux-x86-64 + 0x6568
0x7f9e35cab2ca: ld-linux-x86-64 + 0x202ca
</callstack>
<error>Program termination requested</error>
<date>Mon Jan 12 17:54:02 2026
</date>
<version>Version 24.1.0 Build 115 03/21/2024 SC Pro Edition</version>
</internal_error>
