9 years agoTestbench for 10G Ethernet PHY
I just implemented a 10G Ethernet PHY design using the IP core: "1G/2.5G/5G/10G Multi-rate Ethernet PHY" + pll & reset controller. The Ethernet PHY core should receive the serial data from an SFP+ modul (Stratix 10 SX FPGA) Now, I need to simulate the design to check if everything is working fine. I don't know which input data vector for the Ethernet PHY core I should use and which outputs should expect. Thanks a lot1 Reply
I suggest you refer to this Stratix 10 Low Latency Ethernet 10G MAC Design Example User Guide
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug-20073.pdf Chapter 6: 10G USXGMII Ethernet Design Example for Intel Stratix 10 Devices It provides an example to run the simulation. Regards, skbeh (This message was posted on behalf of Intel Corporation)
