Tcl command to change the output clock frequency of the PLL
I am using a PLL in my platform designer design. I want to change one of the output clock frequency of the PLL using tcl command.
What is the tcl command to change the output clock frequency of the PLL ?
I am using Intel Quartus Pro 23.3
Note: I use the below command to change the clock frequency in Quartus Standard.
set_instance_parameter_value iopll_0 {gui_output_clock_frequency1} {125.000000}
The same command does not work in Quartus pro.
Any suggestions on this issue?
- RichardT_altera
Unfortunately, instance parameters are no longer supported in Pro. Therefore, the instance parameter TCL script flow used in Quartus Standard may not be applicable in Pro.
Instead , please use "Parameterizing an Instantiated IP Core after save_system Command"
Quartus Standard Reference: https://www.intel.com/programmable/technical-pdfs/qps-ugs.pdf
Richard Tan
- RichardT_altera
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
- RichardT_altera
If you have any further questions or concerns, please don't hesitate to let us know.
Richard Tan
