VGopa7
2 years agoTcl command to change the output clock frequency of the PLL
Hi, I am using a PLL in my platform designer design. I want to change one of the output clock frequency of the PLL using tcl command. What is the tcl command to change the output clock frequency o...
RichardT_altera
2 years agoUnfortunately, instance parameters are no longer supported in Pro. Therefore, the instance parameter TCL script flow used in Quartus Standard may not be applicable in Pro.
Instead , please use "Parameterizing an Instantiated IP Core after save_system Command"
Quartus Standard Reference: https://www.intel.com/programmable/technical-pdfs/qps-ugs.pdf
Richard Tan
