System-Console 26.1 java.io.IOException: Cannot run program "ps": CreateProcess error=2
System-Console 26.1 throws this error.
Yet it runs fine. Any fix for it? Tried on multiple computers: Windows 10, 11, ...
FINE: Enabling plugin: com.altera.systemconsole.issp.internal.ISSPPluginProvider
May 07, 2026 2:39:29 PM com.altera.systemconsole.internal.core.SystemConsole$PluginDiscovery loadPlugins
FINE: Discovered plugin: com.altera.systemconsole.monitor.internal.MonitorPluginProvider
May 07, 2026 2:39:29 PM com.altera.systemconsole.internal.core.SystemFilesystem$PluginHandler$2 run
FINE: Enabling plugin: com.altera.systemconsole.monitor.internal.MonitorPluginProvider
FINE: Discovered plugin: com.altera.systemconsole.plugin.pli.PliDeviceProvider
FINE: Enabling plugin: com.altera.systemconsole.plugin.pli.PliDeviceProvider
FINE: Discovered plugin: com.altera.systemconsole.plugin.remotechannel.RemoteChannelPluginProvider
FINE: Enabling plugin: com.altera.systemconsole.plugin.remotechannel.RemoteChannelPluginProvider
java.io.IOException: Cannot run program "ps": CreateProcess error=2, The system cannot find the file specified
at java.base/java.lang.ProcessBuilder.start(Unknown Source)
at java.base/java.lang.Runtime.exec(Unknown Source)
at com.altera.systemconsole.plugin.remotechannel.RemoteChannelTclExtension.isScmdRunning(RemoteChannelTclExtension.java:88)
at com.altera.systemconsole.plugin.remotechannel.RemoteChannelTclExtension.<init>(RemoteChannelTclExtension.java:43)
at com.altera.systemconsole.plugin.remotechannel.RemoteChannelPluginProvider.installTclExtension(RemoteChannelPluginProvider.java:54)
at com.altera.systemconsole.plugin.remotechannel.RemoteChannelPluginProvider.install(RemoteChannelPluginProvider.java:39)
at com.altera.systemconsole.internal.core.SystemFilesystem$PluginHandler$2.run(SystemFilesystem.java:334)
at com.altera.systemconsole.internal.core.SystemFilesystem$PluginHandler.pluginEnabled(SystemFilesystem.java:341)
at com.altera.systemconsole.internal.core.SystemFilesystem$PluginHandler.childrenAdded(SystemFilesystem.java:367)
at com.altera.systemconsole.internal.core.SystemNode.fireChildrenAdded(SystemNode.java:291)
at com.altera.systemconsole.internal.core.SystemNode.addChildren(SystemNode.java:265)
at com.altera.systemconsole.internal.core.SystemConsole$PluginDiscovery.loadPlugins(SystemConsole.java:246)
at com.altera.systemconsole.internal.core.SystemConsole$PluginDiscovery.run(SystemConsole.java:213)
at com.altera.systemconsole.internal.core.SystemExecutor$4.run(SystemExecutor.java:551)
at com.altera.systemconsole.internal.core.SystemExecutor$ComparableTask.run(SystemExecutor.java:151)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.base/java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
at java.base/java.lang.ProcessImpl.create(Native Method)
at java.base/java.lang.ProcessImpl.<init>(Unknown Source)
at java.base/java.lang.ProcessImpl.start(Unknown Source)
... 21 more
May 07, 2026 2:39:29 PM com.altera.systemconsole.internal.core.SystemConsole logWarning
WARNING: Debug Server failed to start
FINE: Discovered plugin: com.altera.systemconsole.scripting.UserScriptSupport
FINE: Enabling plugin: com.altera.systemconsole.scripting.UserScriptSupport
FINE: Discovered plugin: com.altera.systemconsole.scripting.ui.ConsolePlugin
FINE: Enabling plugin: com.altera.systemconsole.scripting.ui.ConsolePlugin
FINE: Discovered plugin: com.altera.systemconsole.sldhubchannel.SldHubPluginProvider
- ShengN_altera
Quartus 26.1 only supported in Windows 11 check this https://www.altera.com/design/guidance/software/os-support
Could you try uninstall and re-install?
- covfefe
Here I am just using System-Console. The requirements should be loser that full Quartus, though I couldn’t find a page for it.
thanks for pointing the requirements to Quartus 26.1, shouldn’t OS-validation be enforced at installation? I’m assuming I’m not the only one who spend days troubleshooting, and forgot to check if Windows 10 support was discontinued
- ShengN_altera
May I know you got problem on Windows 11?
- covfefe
yes, same issue on Windows 11
