9 years agoSynthesis support for SystemVerilog files in Quartus Prime Version 16.0.0
Hi all,
I am trying to synthesize a SystemVerilog (.sv) file in Quartus Prime Version 16.0.0. I get the following error while using "for" statements without the explicit "generate" statement: (error) near text: "for"; expecting "endmodule" The code snippet giving the error is as follows:for(genvar i=0; i<4; i=i+1)
always_ff@(posedge clk)
o_data <= i_data;
I get the above error in spite of having set the "Settings > Verilog HDL Input > Verilog version" to "SystemVerilog". I have also included the comment "// synthesis VERILOG_INPUT_VERSION SYSTEMVERILOG_2005" at the first line of my .sv file. As a workaround, I can get Quartus to synthesize my file correctly using the following edited version of the original code snippet:-
genvar i;
generate for(i=0; i<4; i=i+1) begin : name_1
o_data <= i_data;
end
endgenerate
However, I have a lot of files using the SysthemVerilog syntax, and editing each "for" statement in each file into a "generate for" as in the above example is a tedious task. Is there a way to get Quartus to synthesize the files as they are, in the SystemVerilog syntax of using "for" without an explicit "generate" as above? Thanks! Akshay3 Replies
I get the feeling it is not supported. See here for a list of what SV features are supported:
http://quartushelp.altera.com/current/index.htm#hdl/vlog/vlog_list_sys_vlog.htm - Altera_Forum
The handbook for Q16.1 prime pro talks about enhanced SV support, but you need a pro licence.
--- Quote Start --- Hi all, I am trying to synthesize a SystemVerilog (.sv) file in Quartus Prime Version 16.0.0. I get the following error while using "for" statements without the explicit "generate" statement: (error) near text: "for"; expecting "endmodule" The code snippet giving the error is as follows:
I get the above error in spite of having set the "Settings > Verilog HDL Input > Verilog version" to "SystemVerilog". I have also included the comment "// synthesis VERILOG_INPUT_VERSION SYSTEMVERILOG_2005" at the first line of my .sv file. As a workaround, I can get Quartus to synthesize my file correctly using the following edited version of the original code snippet:-for(genvar i=0; i<4; i=i+1) always_ff@(posedge clk) o_data <= i_data;
However, I have a lot of files using the SysthemVerilog syntax, and editing each "for" statement in each file into a "generate for" as in the above example is a tedious task. Is there a way to get Quartus to synthesize the files as they are, in the SystemVerilog syntax of using "for" without an explicit "generate" as above? Thanks! Akshay --- Quote End --- I think you need to declare "i" as an "int" -> for (int i = 0;.....genvar i; generate for(i=0; i<4; i=i+1) begin : name_1 always_ff@(posedge clk) o_data <= i_data; end endgenerate
