Synthesis error while using interface parameters
Hi
I have come across an issue with Quartus synthesis. As shown in the code below, I have defined a simple `data_stream_i` interface and a simple `demux` module (Demux 1 channels to 2 channels using dest signal for routing). I was trying to use parameters from the input interface (`i_in`) to instance another, internal interface (`i_in_reg`). Unfortunately, the module fails to synthesize - I get `Error(13433): Verilog HDL Defparam Statement error at demux.sv(8): value for parameter "TDATA_T_WIDTH" must be constant expression`.
I have come to the conclusion that the `i_in_reg` interface can not be created with the `data_t` type, as long as the `TDATA_WIDTH` parameter is assigned to any of the `data_stream_i` interface parameters.
This error’s cause is described as: “In a Defparam Statement at the specified location in a Verilog Design File (.v), you specified a value for the specified parameter that is not a constant expression. You must specify only constant expressions for parameter values.” (here). However, all values used by me are, in fact, constant. Moreover, this code can be synthesized with Vivado.
Could you help me with this issue?
Thank you in advance!
Steps to replicate:
- Use `Quartus Prime Pro Edition 20.4.0` with any devices installed
- Create a new project, add following code to `demux.sv` file.
- Set `demux.sv` as Top-level Entity
- Run `Analysis & Synthesis`
Used code:
/* * Demux 1 channels to 2 channels using dest signal for routing */ interface data_stream_i #( parameter DATA_WIDTH = 512, type TDATA_T = logic [DATA_WIDTH-1:0], parameter TDATA_T_WIDTH = $bits(TDATA_T) ) (); logic tvalid; logic tready; TDATA_T tdata; modport master ( output tdata, input tready, output tvalid ); modport slave ( input tdata, output tready, input tvalid ); endinterface : data_stream_i module demux #()( input logic clk, input logic reset, data_stream_i.slave i_in, data_stream_i.master i_out[1:0], input logic dest ); localparam TDATA_WIDTH = i_in.TDATA_T_WIDTH; //Using data_t as TDATA_T type triggers: Error(13433): Verilog HDL Defparam Statement error at axis_demux.sv(8): value for parameter "TDATA_T_WIDTH" must be constant expression //This is true for: TDATA_WIDTH = i_in.TDATA_T_WIDTH; TDATA_WIDTH = $bits(i_in.TDATA_T); and TDATA_WIDTH = i_in.DATA_WIDTH //Defining TDATA_WIDTH = 512; results in successful synthesis typedef struct packed { logic [TDATA_WIDTH-1:0] base; logic dest; } data_t; data_stream_i #(.TDATA_T(data_t)) i_in_reg(); logic [1:0] out_reg_tready; assign i_in_reg.tvalid = i_in.tvalid; assign i_in.tready = out_reg_tready[i_in_reg.tdata.dest]; assign i_in_reg.tdata.base = i_in.tdata; assign i_in_reg.tdata.dest = dest; generate for (genvar i=0; i < 2; i++) begin : OUTPUT_REG assign out_reg_tready[i] = i_out[i].tready; assign i_out[i].tvalid = i_in_reg.tdata.dest == i ? i_in_reg.tvalid : 1'b0; assign i_out[i].tdata = i_in_reg.tdata;; end endgenerate endmodule : demux
- sstrell
Did you mean to use "typedef" instead of "type"?
- PWzorek
No - I did not. "type" is a keyword for TDATA_T parameter.
This module can be synthesized if I pass `512` value to TDATA_WIDTH parameter:localparam TDATA_WIDTH = 512;The rest of this code is correct and does not cause any errors..
- RichardT_altera
This could be potential bug. I have filed a case to engineering team to check on this.
Please do expect that any work that involve engineering may takes some time, depending on the issue complexity.Best Regards,
Shyan Yew (Richard)
