KarelSterckx's avatar
KarelSterckx
3 years ago
Syntax error in initial block
I am using Quartus Prime Lite Edition v22.1.1
In my Verilog HDL code, I include the following initial block:
initial begin
div = 4’b0;
lpc = 4’b0;
pa = 4’b0;
plc_lsb = 8’b0;
plc_usb = 8’b0;
dsb = 9’b0;
end
A syntax error in every line of the initial block is generated when I compile the code. I do not see anything wrong with the code though.
  • Thanks a lot. That is indeed the problem. I have no idea how that back tick crept in as I do not have it on my keyboard. Perhaps I copied it from somewhere though I cannot remember.
  • _AK6DN_'s avatar
    _AK6DN_
    You need to provide more info.
    What exactly is the error message(s) that are being generated?
    What is the code context of the initial block (ie, the verilog code before the block).
    Guessing it could be the initial block is not valid in that context, or the items you assign in the block are not reg variables.
    • KarelSterckx's avatar
      KarelSterckx
      The error messages for each line within the initial block are:
      Error (10170): Verilog HDL syntax error at dsb.v(10) near text: . Check for and fix any syntax errors that appear immediately before or at the specified keyword.
      Error (10170): Verilog HDL syntax error at dsb.v(10) near text: " "; expecting ";". Check for and fix any syntax errors that appear immediately before or at the specified keyword.
      Code before the initial block is:
      module dsb (clk_c, plc_lsb, plc_usb, dsb);
      input clk_c;
      output plc_lsb, plc_usb, dsb;
      reg [3:0] div, lpc, pa; // div = counter used to obtain clk_m from clk_c
      wire [3:0]sub, add;
      reg [7:0] plc_lsb, plc_usb;
      reg [8:0] dsb;
      initial begin
      div = 4’b0;
      lpc = 4’b0;
      pa = 4’b0;
      plc_lsb = 8’b0;
      plc_usb = 8’b0;
      dsb = 9’b0;
      end
  • _AK6DN_'s avatar
    _AK6DN_
    Ok, I think I found the problem.
    I copied your code via cut/paste and it barfs when I compile.
    It appears in your constants in the initial block you used a unicode apostrophe character instead of a single ascii apostrophe (').
    At least that is what I got when I did a cut/paste of your code verbatim.
    Once I went in and edited the constants to use a single ascii apostrophe (ie, like 4'b0) it compiled Ok.
    foo.c is your code. The apostrophe character in the constants is '342 200 231' instead of the single ascii apostrophe (') in the edited code bar.c.
    par[533] od -c foo.v
    0000000   i   n   i   t   i   a   l       b   e   g   i   n  \r  \n   d
    0000020   i   v       =       4 342 200 231   b   0   ;  \r  \n   l   p
    0000040   c       =       4 342 200 231   b   0   ;  \r  \n   p   a
    0000060   =       4 342 200 231   b   0   ;  \r  \n   p   l   c   _   l
    0000100   s   b       =       8 342 200 231   b   0   ;  \r  \n   p   l
    0000120   c   _   u   s   b       =       8 342 200 231   b   0   ;  \r
    0000140  \n   d   s   b       =       9 342 200 231   b   0   ;  \r  \n
    0000160   e   n   d  \r  \n
    0000165
    par[536]
    par[536] od -c bar.v
    0000020   i   v       =       4   '   b   0   ;  \r  \n   l   p   c
    0000040   =       4   '   b   0   ;  \r  \n   p   a       =       4   '
    0000060   b   0   ;  \r  \n   p   l   c   _   l   s   b       =       8
    0000100   '   b   0   ;  \r  \n   p   l   c   _   u   s   b       =
    0000120   8   '   b   0   ;  \r  \n   d   s   b       =       9   '   b
    0000140   0   ;  \r  \n   e   n   d  \r  \n
      KarelSterckx
  • SyafieqS's avatar
    SyafieqS
    Let me know if you manage to resolve the issue
  • SyafieqS's avatar
    SyafieqS
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
