10 years ago
Synchronization on falling and rising edges
Hi, I need help .
I need to synchronize to the falling and rising edge encoder signal "A" .
Both these edges need to work with the signal "count".
I have this error : Error (10028): Can't resolve multiple constant drivers for net "number[0]" at encoder.vhd(62)
My code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity encoder is
port( clk:in std_logic;
A:in std_logic;
B:in std_logic;
number:buffer unsigned(11 downto 0):=(others=>'0'));
end encoder;
architecture main of encoder is
signal count: unsigned(11 downto 0):=(others=>'0');
begin
ld:process(A)
begin
if rising_edge(A) then
if B='0' then
number<=number + 1;
end if;
if B='1' then
number<=number - 1 ;
end if;
end if;
end process;
ld1:process(A)
begin
if falling_edge(A) then
if B='1' then
number<=number + 1;
end if;
if B='0' then
end if;
end if;
end process;
end main;
this is signal of encoder
http://3.bp.blogspot.com/_qwqti0pxucw/tjbvdoimaxi/aaaaaaaaauk/m6on7fybr0o/s1600/encoding.png
    multiple drivers are not allowed in fpga design(or digital design but possible in analogue domain).
    you can use two counters then mux the result but I don't see why you will ever need that as it looks like DDR signal
    Hello Tomsik,
    I had a similar problem some time ago.
    The trick i used is to generate the flank detections on an internal FPGA clock.
    This clock is normally a lot faster than the ecoder timing, so it should not be a problem.
    wire a;
    wire b;
    assign a = KEY[0];
    assign b = KEY[1];
    reg aPrev;
    reg bPrev;
    always @(posedge CLOCK_50)
    begin
    // mounting flank on A
    if (a > aPrev)
    begin
    if (b==0)
    r <= r+1;
    else
    r <= r-1;
    end
    // descending flank on a
    if (a < aPrev)
    begin
    if (b==1)
    r <= r + 1;
    else
    r <= r - 1;
    end
    aPrev<=a;
    bPrev<=b;
    end
    Johi.
    This is not VHDL.
    Works only on second turn encoder.
    But I need capture the falling edge and affect the signal.
    OK problem resolved!
    library ieee;
    entity encoder is
    state_A:in std_logic;
    B:in std_logic;
    end encoder;
    signal number1:unsigned (11 downto 0):=(others=>'0');
    signal number2:unsigned (11 downto 0):=(others=>'0');
    signal cislo:unsigned (11 downto 0):=(others=>'0');
    signal NOTstate_A: std_logic;
    begin
    ld:process(state_A,NOTstate_A)
    begin
    if rising_edge(state_A) then
    if B='0' then
    number1<=number1 + 1;
    end if;
    if B='1' then
    number1<=number1 - 1;
    end if;
    end if;
    if rising_edge(NOTstate_A) then
    if B='1' then
    number2<=number2 + 1;
    end if;
    if B='0' then
    number2<=number2 - 1;
    end if;
    end if;
    end process;
    NOTstate_A<=not state_A;
    cislo<=number1+number2;
    number<=not cislo;
    end main;
    This is unlikely to work in real hardware. You have generated a logic clock and the timing between the two clocks is likely to be variable.
    --- Quote Start ---
    --- Quote End ---
    My program works excellently. The outputs of the rotary encoder are routed on capacitor and schmitt gate .
    Hello, please How to my code takes 756 total logic elements. Can I somehow save the data to an external RAM or internal RAM . How?
    library ieee;
    entity Number_converter is
    port( INPUT12bit: in unsigned (11 downto 0);
    digit1: out unsigned (11 downto 0);
    digit2: out unsigned (11 downto 0);
    digit3: out unsigned (11 downto 0);
    digit4: out unsigned (11 downto 0));
    end entity;
    architecture main of Number_converter is
    signal INPUT12bit_INT:integer range 0 to 4096;
    attribute ramstyle: string;
    attribute ramstyle of digit4 : signal is "M9K";
    begin
    digit1<=(INPUT12bit rem 10)/1;
    digit2<=(INPUT12bit rem 100)/10;
    digit3<=(INPUT12bit rem 1000)/100;
    digit4<=(INPUT12bit/1000);
    end main;
    divide and remainder take a lot of logic to implement when the denominator is not 2^n.
    You also cannot turn an output into a ram.
    --- Quote Start ---
    --- Quote End ---
    Please, How?
