10 years agoSynchronization on falling and rising edges
Hi, I need help . I need to synchronize to the falling and rising edge encoder signal "A" . Both these edges need to work with the signal "count". I have this error : Error (10028): Can'...
10 years agoHello, please How to my code takes 756 total logic elements. Can I somehow save the data to an external RAM or internal RAM . How?
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity Number_converter is port( INPUT12bit: in unsigned (11 downto 0); digit1: out unsigned (11 downto 0); digit2: out unsigned (11 downto 0); digit3: out unsigned (11 downto 0); digit4: out unsigned (11 downto 0)); end entity; architecture main of Number_converter is signal INPUT12bit_INT:integer range 0 to 4096; attribute ramstyle: string; attribute ramstyle of digit4 : signal is "M9K"; begin digit1<=(INPUT12bit rem 10)/1; digit2<=(INPUT12bit rem 100)/10; digit3<=(INPUT12bit rem 1000)/100; digit4<=(INPUT12bit/1000); end main;
