10 years agoSynchronization on falling and rising edges
Hi, I need help . I need to synchronize to the falling and rising edge encoder signal "A" . Both these edges need to work with the signal "count". I have this error : Error (10028): Can'...
10 years agoOK problem resolved!
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity encoder is port( clk:in std_logic; state_A:in std_logic; B:in std_logic; number:buffer unsigned(11 downto 0):=(others=>'0')); end encoder; architecture main of encoder is signal number1:unsigned (11 downto 0):=(others=>'0'); signal number2:unsigned (11 downto 0):=(others=>'0'); signal cislo:unsigned (11 downto 0):=(others=>'0'); signal NOTstate_A: std_logic; begin ld:process(state_A,NOTstate_A) begin if rising_edge(state_A) then if B='0' then number1<=number1 + 1; end if; if B='1' then number1<=number1 - 1; end if; end if; if rising_edge(NOTstate_A) then if B='1' then number2<=number2 + 1; end if; if B='0' then number2<=number2 - 1; end if; end if; end process; NOTstate_A<=not state_A; cislo<=number1+number2; number<=not cislo; end main;
