10 years agoSynchronization on falling and rising edges
Hi, I need help . I need to synchronize to the falling and rising edge encoder signal "A" . Both these edges need to work with the signal "count". I have this error : Error (10028): Can'...
10 years agoThis is unlikely to work in real hardware. You have generated a logic clock and the timing between the two clocks is likely to be variable.
