Support Logic Generation Error
Thanks for contacting Intel. I'm assigned to support request.
I'll investigate on this case and get back to you soon once I have any finding.
Meanwhile can I check with you on
- Please share the IP names you are using in your design.
- Is it possible for you to share archived design? If yes, kindly attach.
Thanks for your patience.
Harsh M
Hi @Harshx ,
I too am facing the same issue when using an F-Tile for the device AGI027R31B1E1V and Quartus 24.1 Prime Pro. Design in question is the Intel OFS F-Tile Design which I am porting to my own custom board.
I have changed the Ethernet Subsystem to a single port 400GCAUI-4 using the 4 FHT Channels in one F-Tile and am using my own constraints. When compiling the same error pops up.
Error(22241): Cannot place the block hssi_wrapper|hssi_ss|hssi_ss|U_eth_f_inst_p16|eth_f_top_p16|hip_inst|per_xcvr[0].x_bb_f_bk at location fht_ch0 because it uses port next_bonding_link that is not present at this location.
Any updates on this case? It would be greatly helpful.
Thank you,
Best Regards.
