13 years ago
Subtraction with numeric_Std doesn't work
Hello
What am i doing in wrong in the code below. subtraction doesn't work! I am using numeric_std and the numbers are in twos complement format.
// mattgust
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use work.OF_DET.all;
entity Arith is
    port(
            op_code    : in std_logic_vector(1 downto 0);
            a_in        : in std_logic_vector(7 downto 0);
            b_in        : in std_logic_vector(7 downto 0);
            zero_det    : out std_logic;
            overflow    : out std_logic;
            alu_out    : out std_logic_vector(7 downto 0)
end entity Arith;
architecture ALU of Arith is
signal Tmp_a    :    signed(a_in'range):=(others=>'0');
signal Tmp_b    :    signed(b_in'range):=(others=>'0');
signal Tmp_out    :    signed(alu_out'range):=(others=>'0');
begin
    Tmp_a <= signed(a_in);
    Tmp_b <= signed(b_in);
    ALU:process(Tmp_out, Tmp_a, Tmp_b)
    begin
        case op_code is
            when "00" =>
                Tmp_out <= Tmp_a and Tmp_b;
            when "01" =>
                Tmp_out <=  Tmp_a or Tmp_b;
            when "10" =>
                Tmp_out <=  Tmp_a + Tmp_b;
                overflow <= detect_overflow(Tmp_out, Tmp_a, Tmp_b);
                zero_det <= detect_zero(Tmp_out);
            when "11" =>
                Tmp_out <=    Tmp_a - Tmp_b;
            when others =>
                null;
        end case;
            alu_out <= std_logic_vector(Tmp_out);
    end process;
end architecture ALU;
-- Copyright (C) 1991-2012 Altera Corporation
-- Your use of Altera Corporation's design tools, logic functions
-- and other software and tools, and its AMPP partner logic
-- functions, and any output files from any of the foregoing
-- (including device programming or simulation files), and any
-- associated documentation or information are expressly subject
-- to the terms and conditions of the Altera Program License
-- Subscription Agreement, Altera MegaCore Function License
-- Agreement, or other applicable license agreement, including,
-- without limitation, that your use is for the sole purpose of
-- programming logic devices manufactured by Altera and sold by
-- Altera or its authorized distributors.  Please refer to the
-- applicable agreement for further details.
-- This file contains a Vhdl test bench template that is freely editable to
-- suit user's needs .Comments are provided in each section to help the user
-- fill out necessary details.
-- Generated on "11/17/2012 12:17:48"
-- Vhdl Test Bench template for design  :  Arith
-- Simulation tool : ModelSim-Altera (VHDL)
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY Arith_vhd_tst IS
END Arith_vhd_tst;
ARCHITECTURE Arith_arch OF Arith_vhd_tst IS
-- constants
-- signals
SIGNAL a_in : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL b_in : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL alu_out : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL op_code : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL overflow : STD_LOGIC;
SIGNAL zero_det : STD_LOGIC;
COMPONENT Arith
    PORT (
    a_in : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
    alu_out : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
    b_in : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
    op_code : IN STD_LOGIC_VECTOR(1 DOWNTO 0);
    overflow : OUT STD_LOGIC;
    zero_det : OUT STD_LOGIC
END COMPONENT;
BEGIN
    i1 : Arith
    PORT MAP (
-- list connections between master ports and signals
    a_in => a_in,
    alu_out => alu_out,
    b_in => b_in,
    op_code => op_code,
    overflow => overflow,
    zero_det => zero_det
    process
    begin
        op_code <="10";
        wait for 300 ns;
        op_code <="11";
        wait for 300 ns;
    end process;
    process
    begin
        a_in <= "01111110";
        b_in <= "00000010";
        wait for 50 ns;
        a_in <= "00000010";
        b_in <= "00000010";
        wait for 50 ns;
        a_in <= "01111111";
        b_in <= "00000000";
        wait for 50 ns;
        a_in <= "01111111";
        b_in <= "10000000";
        wait for 50 ns;
        a_in <= "00011110";
        b_in <= "11011000";
        wait for 50 ns;
        a_in <= "00000010";
        b_in <= "11111110";
        wait for 50 ns;
        a_in <= "10000000"; -- Subtraktion härifrån
        b_in <= "00000010";
        wait for 50 ns;
        a_in <= "01111111";
        b_in <= "11111110";
        wait for 50 ns;
        a_in <= "00001000";
        b_in <= "00001000";
        wait for 50 ns;
        a_in <= "01111111";
        b_in <= "10000000";
        wait for 50 ns;
        a_in <= "00011110";
        b_in <= "11011000";
        wait for 50 ns;
        a_in <= "00000010";
        b_in <= "11111110";
        wait for 50 ns;
    end process;
END Arith;
    Hi all,
    I have a subtraction part in my code:
    x<=unsigned(DataSent);
    y<=N/2;
    y1<=(unsigned(x)-y);
    my variables datasent ,x,y,y1,all are integers.
    when i comment the statement
    the variable x rightly has the datasent value but when the above statement is not commented the code breaks at y1<=unsigned(x)-y
    How can x loose its value?
    It shows the -214748368
    how do i make x store the right value ?
    say if datasent is 231 and y-N/2 is 6 for N=12
    what correction has to be done to get y1= 231-6=225
    Can someone verify why the processing stops at the line y1<=x-y?
    Thanks in Advance
    If x is indeed an integer, then this code:
    Will not compile. unsigned() can be used to convert a std_logic_vector to unsigned, but if you are converting from an integer, then you need to use the to_unsigned() function, and specify the number of bits for the result.
    Besides
    y1<=x-y;
    should be enough
    CAn you post the full code. Your snippet has all sorts of type errors.
    --- Quote Start ---
    --- Quote End ---
    yes below is the entire code
    library ieee;
    use ieee.std_logic_arith.all;
    use IEEE.math_real.all; -- for UNIFORM, TRUNC functions
    USE ieee.numeric_std.ALL; -- for TO_UNSIGNED function
    use ieee.STD_LOGIC_UNSIGNED.all;
    use ieee.std_logic_textio.all;
    entity ADwgn is
    port
    diginp:in std_logic_vector(11 downto 0);
    digiop:out std_logic_vector(11 downto 0);
    x:inout integer;
    result:out std_logic_vector(11 downto 0);
    lo_val:out integer
    end;
    architecture a of ADwgn is
    subtype unsigned is integer range 0 to 255;
    signal y1,R,y: unsigned := 0;
    signal rst_n: std_logic:='1';
    signal N: integer:=12;
    signal middle: integer:=0;
    signal c:real;
    signal rand_wave: std_logic_vector(11 downto 0);
    signal rand: integer:=0;
    signal mean: integer:=1;
    signal variance:integer:= 2;
    begin
    process(rst_n)
    variable RandomVal : real ;
    variable DataSent : integer ; -- Random integer value in range 0..256
    -- Declare seeds and initialize
    -- Uniform uses seeds as state information,
    -- so initialize only once
    variable DataSent_seed1 : positive := 7 ; -- Seed values for random generator
    variable DataSent_seed2 : positive := 1 ;
    VARIABLE stim: std_logic_vector(11 DOWNTO 0); -- Random 12-bit stimulus
    begin
    if rst_n='0' then
    x<=0;
    elsif rst_n='1' then
    for i in 1 to 10 loop
    -- Generate a value between 0.0 and 1.0 (non-inclusive)
    uniform(DataSent_seed1, DataSent_seed2, RandomVal) ;
    -- Convert to integer in range of 0 to 255
    DataSent := integer(trunc(RandomVal*256.0)) ;
    stim := std_logic_vector(to_unsigned(DataSent, stim'LENGTH)); -- convert to std_logic_vector
    lo_val<=i;
    end loop;
    --tmp_a<= x;
    y<=N/2;
    y1<=(x-y); -- set mean to 0 PROBLEM WITH CODE AT THIS LINE
    result<=stim;
    rst_n<='0';
    middle<= (12/N);
    c<=sqrt(real(middle));
    --rand<=unsigned(real(x)*c); -- PROBLEM ARISES HERE ALSO
    --R<=integer(rand);
    -- rand_wave<=std_logic_vector(to_unsigned(R,rand_wave'LENGTH)) ; -- adjust variance to 1
    -- rand_wave<=std_logic_vector(to_unsigned(x, rand_wave'LENGTH))
    end if;
    digiop<=diginp xor stim;
    --x' <= mean + (sqrt(real(variance)) * x)
    end process;
    end;
    --When the algorithm finishes, X will be our unit normal random.
    --X can be further modified to have a particular mean and variance, e.g.:
    THe problem comes as you are missing several signals from the sensitivity list, namely x,y, y1, N, middle. But theres a couple of other issues:
    The values only get updated when rst_n is '1'. It starts as '1', but will imediatly goes to '0'.
    You declared your own subtype called unsigned. This is a bad idea, as numeric_std and std_logic_arith also declare unsigned types. You're going to have problems if you stick with these. I suggest deleting your custom unsigned subtype and the non-standard std_logic_arith library.
    Also: I assume you know this code is not synthesisable (ie. You cannot put it on an FPGA) - I guess this is some kind of simulation model?
    --- Quote Start ---
    --- Quote End ---
    Hi ,
    Yes this is only a simulation model.
    i simply specify y1<=integer(x-y ) where all are declared as integer .Though x and y hold there corresponding values say 231 and 6, y1 displays only its maximum range i.e -214748368.
    And when i remove the subtype declaration it says unsigned is not directly visible.
    Thanks in advance!
    --- Quote Start ---
    i simply specify y1<=integer(x-y ) where all are declared as integer .Though x and y hold there corresponding values say 231 and 6, y1 displays only its maximum range 214748368.
    --- Quote End ---
    With the code as it is, this is impossible, as that would be out of range of the subtype and would cause an error.
    This is because numeric_std and std_logic_arith both declare unsigned. And so it doesnt know which one to use. So Delete the non-standard std_logic_arith library like I said.
