11 years ago --- Quote Start --- i simply specify y1<=integer(x-y ) where all are declared as integer .Though x and y hold there corresponding values say 231 and 6, y1 displays only its maximum range 214748368. --- Quote End --- With the code as it is, this is impossible, as that would be out of range of the subtype and would cause an error.
And when i remove the subtype declaration it says unsigned is not directly visible.
This is because numeric_std and std_logic_arith both declare unsigned. And so it doesnt know which one to use. So Delete the non-standard std_logic_arith library like I said.
