13 years agoSubtraction with numeric_Std doesn't work
Hello
What am i doing in wrong in the code below. subtraction doesn't work! I am using numeric_std and the numbers are in twos complement format. // mattgustlibrary ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use work.OF_DET.all;
entity Arith is
port(
op_code : in std_logic_vector(1 downto 0);
a_in : in std_logic_vector(7 downto 0);
b_in : in std_logic_vector(7 downto 0);
zero_det : out std_logic;
overflow : out std_logic;
alu_out : out std_logic_vector(7 downto 0)
end entity Arith;
architecture ALU of Arith is
signal Tmp_a : signed(a_in'range):=(others=>'0');
signal Tmp_b : signed(b_in'range):=(others=>'0');
signal Tmp_out : signed(alu_out'range):=(others=>'0');
begin
Tmp_a <= signed(a_in);
Tmp_b <= signed(b_in);
ALU:process(Tmp_out, Tmp_a, Tmp_b)
begin
case op_code is
when "00" =>
Tmp_out <= Tmp_a and Tmp_b;
when "01" =>
Tmp_out <= Tmp_a or Tmp_b;
when "10" =>
Tmp_out <= Tmp_a + Tmp_b;
overflow <= detect_overflow(Tmp_out, Tmp_a, Tmp_b);
zero_det <= detect_zero(Tmp_out);
when "11" =>
Tmp_out <= Tmp_a - Tmp_b;
when others =>
null;
end case;
alu_out <= std_logic_vector(Tmp_out);
end process;
end architecture ALU; -- Copyright (C) 1991-2012 Altera Corporation
-- Your use of Altera Corporation's design tools, logic functions
-- and other software and tools, and its AMPP partner logic
-- functions, and any output files from any of the foregoing
-- (including device programming or simulation files), and any
-- associated documentation or information are expressly subject
-- to the terms and conditions of the Altera Program License
-- Subscription Agreement, Altera MegaCore Function License
-- Agreement, or other applicable license agreement, including,
-- without limitation, that your use is for the sole purpose of
-- programming logic devices manufactured by Altera and sold by
-- Altera or its authorized distributors. Please refer to the
-- applicable agreement for further details.
-- This file contains a Vhdl test bench template that is freely editable to
-- suit user's needs .Comments are provided in each section to help the user
-- fill out necessary details.
-- Generated on "11/17/2012 12:17:48"
-- Vhdl Test Bench template for design : Arith
-- Simulation tool : ModelSim-Altera (VHDL)
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY Arith_vhd_tst IS
END Arith_vhd_tst;
ARCHITECTURE Arith_arch OF Arith_vhd_tst IS
-- constants
-- signals
SIGNAL a_in : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL b_in : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL alu_out : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL op_code : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL overflow : STD_LOGIC;
SIGNAL zero_det : STD_LOGIC;
COMPONENT Arith
PORT (
a_in : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
alu_out : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
b_in : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
op_code : IN STD_LOGIC_VECTOR(1 DOWNTO 0);
overflow : OUT STD_LOGIC;
zero_det : OUT STD_LOGIC
END COMPONENT;
BEGIN
i1 : Arith
PORT MAP (
-- list connections between master ports and signals
a_in => a_in,
alu_out => alu_out,
b_in => b_in,
op_code => op_code,
overflow => overflow,
zero_det => zero_det
process
begin
op_code <="10";
wait for 300 ns;
op_code <="11";
wait for 300 ns;
end process;
process
begin
a_in <= "01111110";
b_in <= "00000010";
wait for 50 ns;
a_in <= "00000010";
b_in <= "00000010";
wait for 50 ns;
a_in <= "01111111";
b_in <= "00000000";
wait for 50 ns;
a_in <= "01111111";
b_in <= "10000000";
wait for 50 ns;
a_in <= "00011110";
b_in <= "11011000";
wait for 50 ns;
a_in <= "00000010";
b_in <= "11111110";
wait for 50 ns;
a_in <= "10000000"; -- Subtraktion härifrån
b_in <= "00000010";
wait for 50 ns;
a_in <= "01111111";
b_in <= "11111110";
wait for 50 ns;
a_in <= "00001000";
b_in <= "00001000";
wait for 50 ns;
a_in <= "01111111";
b_in <= "10000000";
wait for 50 ns;
a_in <= "00011110";
b_in <= "11011000";
wait for 50 ns;
a_in <= "00000010";
b_in <= "11111110";
wait for 50 ns;
end process;
END Arith;
