13 years agoFair enough. Using package and functions may be good exercise for study but you don't really need two adders and two subtractors for same operations.
Thus, for practical design I will do the following(code not tested):
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity Arith is
port(
op_code : in std_logic_vector(1 downto 0);
a_in : in std_logic_vector(7 downto 0);
b_in : in std_logic_vector(7 downto 0);
zero_det : out std_logic;
overflow : out std_logic;
alu_out : out std_logic_vector(7 downto 0)
end entity Arith;
architecture ALU of Arith is
signal Tmp_a : signed(8 downto 0) :=(others=>'0');
signal Tmp_b : signed8 downto 0) :=(others=>'0');
signal Tmp_out : signed(8 downto 0) :=(others=>'0');
begin
Tmp_a <= resize(signed(a_in),9);
Tmp_b <= resize(signed(b_in),9);
ALU:process(op_code,Tmp_out, Tmp_a, Tmp_b)
begin
case op_code is
when "00" => Tmp_out <= Tmp_a and Tmp_b;
when "01" => Tmp_out <= Tmp_a or Tmp_b;
when "10" => Tmp_out <= Tmp_a + Tmp_b;
when "11" => Tmp_out <= Tmp_a - Tmp_b;
when others => null;
end case;
alu_out <= std_logic_vector(Tmp_out(7 downto 0));
overflow <= Tmp_out(8) xor Tmp_out(7);
zero_det <= '0';
if Tmp_out = "000000000" then
zero_det <= '1';
end if;
end process;
end architecture ALU;
Also notice that your design is all combinatorial. Nothing wrong about that but once you integrate with registers then you may decide to add registers. Moreover you can reduce adder/subtractor to one adder only by negating the input (negation require invert and add 1, a small adder): Tmp_out <= Tmp_a + Tmp; --before case ... when "10" => Tmp <= Tmp_b; when "11" => Tmp <= -Tmp_b;
