Altera_ForumHonored Contributor13 years agoSubtraction with numeric_Std doesn't work Hello What am i doing in wrong in the code below. subtraction doesn't work! I am using numeric_std and the numbers are in twos complement format. // mattgust library ieee; use ieee....Show Morealu_fail.jpg71 KB
Altera_ForumHonored Contributor13 years agoThank you for your fast replies. I will rewrite my overflow detector with your guidelines.
Recent DiscussionsTiming analysis - long combinational pathQuartusPro 25.3 Crashed after using the Signal Tap Logic AnalyzerDuplicate_hierarchy_depth / duplicate_registerAutomatically added negative node for TDS output doesn't work with Agilex 5Quartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SG
