18 years agostd_logic to std_logic_vector in port map
I am newbie in VHDL design and reading literature did not help ...
I created entity to sync signal(s) to clk. I would like to have it generic and use it for both single signals (n=1) and vectors (n>1). The entity is declared as:entity sync2 is
generic (
n : positive := 2 -- width
port (
-- inputs
d : in std_logic_vector (n-1 downto 0);
clk : in std_logic; -- clock
reset : in std_logic; -- asynchronous reset
-- outputs
q : out std_logic_vector (n - 1 downto 0)
end entity sync2; It works perfectly for vectors but I do not know, how to connect std_logic signal to the input vector, which is in this case std_logic_vector(0 downto 0); Or is it possible to overload the declaration so the d is std_logic? signal sig1 : std_logic;
signal sig2 : std_logic;
-- Instantiation of entity
sync : entity work.sync2
generic map ( n => 1 )
port map (
d => sig1,
q => sig2,
reset => reset,
clk => clk
