14 years agoSource Synchronous Interface - Hold Failure
Hi all,
I've a design in which FPGA receive data in DDR with the clock (200MHz) and they are edge aligned. So FPGA shall shift clock 90° in order to capture data correctly and for that I've instantiated a PLL in source synchronous mode that shift it if 1.25ns I gave the "usual" constraint for this kind of interface. create_clock -name AD_CLK_IN -period 5.0 [get_ports AD_CLK] create_clock -name virtual_ad_clk -period 5.0 derive_pll_clocks derive_clock_uncertainty From the AD datasheet (that feed clock and data to FPGA) it is stated that: 1- Data can come out respect to the clock +/- 50ps 2- Morever clock can have a dutycycle that is not 50% but could be 45% to 55%, so 5% is 250ps that I've to keep in account. For theese reason I set up the following contraint set_input_delay -max 0.050 -clock virtual_ad_clk [get_ports AD_IN[*]] set_input_delay -min -0.300 -clock virtual_ad_clk [get_ports AD_IN[*]] set_input_delay -max 0.050 -clock virtual_ad_clk -clock_fall [get_ports AD_IN[*]] -add_delay set_input_delay -min -0.300 -clock virtual_ad_clk -clock_fall [get_ports AD_IN[*]] -add_delay Until now it's only a confirm that I ask, moreover I've though of take care of 45% - 55% duty cycle with clock uncertainty, but in the end was simpler to take in account what this could do on data. Ok now the problem is that in Timequest I've failing path in Hold analisys, in slow corner mode. I report the paths in some panels as suggested by Rysc guide with this commands: 1) Create a setup panel under ADIN named setup report_timing -setup -npaths 100 -detail full_path -from_clock virtual_ad_clk -panel_name ADIN||setup 2) Create a setup panel under ADIN named hold report_timing -hold -npaths 100 -detail full_path -from_clock virtual_ad_clk -panel_name ADIN||hold The problem is in the HOLD that has a slack of about -0.700ns. Setup is ok and has a slack of + 1.6ns. In order to fix them since I've the PLL that is phasing the clock what I assume is that I can move PLL out shift in order to center the window, is that right way to do? It is the first time that happen to me to have path that fails in Source Sync mode. The strange thing in my opinion is that I see that virtual clock and the clock generated by PLL has a lot of skew: 3.36ns! In attachment there is also the Timequest analisys. Thanks in advance for help.
