9 years agoSingle multiplier takes up a whole DSP block for
I'm using a Cyclone V SOC FPGA. Currently my design has 8 multipliers (which I coded in VHDL instead of instantiating). The inputs to the multipliers are 12 and 16 bits wide. According to this document: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/wp/wp-01159-arriav-cyclonev-dsp.pdf I expected the tool to pack 2 multipliers into a single DSP block - so that for 8 multipliers only 4 DSP blocks shall be consumed. Unfortunately - the compilation report shows that 8 DSP blocks are consumed (one per each multiplier). I tried to change the synthesis behavior to area driven - but nothing changed. Any idea what can cause such behavior ?3 Replies
Can you show the VHDL code? Have you tried instantiating the multipliers from the IP Catalog instead of using code inference?
--- Quote Start --- Have you tried instantiating the multipliers from the IP Catalog instead of using code inference? --- Quote End --- No. I preferred pure HDL since I want to parameterize the multiplier with generics during compilation.entity multiplier is generic ( LOCATION_FIRST_RESULT_BIT : natural ; WIDTH_A : positive ; WIDTH_B : positive ; WIDTH_RESULT : positive ) ; port ( IN_A : in std_logic_vector ( WIDTH_A - 1 downto 0 ) ; IN_B : in std_logic_vector ( WIDTH_B - 1 downto 0 ) ; OUT_RESULT : out std_logic_vector ( WIDTH_RESULT - 1 downto 0 ) ) ; end entity multiplier ; architecture rtl_multiplier of multiplier is signal signed_multiplier_result : signed ( WIDTH_B + WIDTH_A - 1 downto 0 ) ; begin signed_multiplier_result <= signed ( IN_B ) * signed ( IN_A ) ; OUT_RESULT <= std_logic_vector ( signed_multiplier_result ( WIDTH_RESULT + LOCATION_FIRST_RESULT_BIT - 1 downto LOCATION_FIRST_RESULT_BIT ) ) ; end architecture rtl_multiplier ; - Altera_Forum
According to my observation, Quartus uses all available DSP block before it starts packing multipliers. See same-topic discussion at Edaboard
http://www.edaboard.com/showthread.php?t=368754 I managed to fill up all 25 DSP blocks of Cyclone5 A2 with this test
;library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity test1 is generic( n : integer := 50; w : integer := 18 ); port( clk : in STD_LOGIC; sel : in integer range 0 to n-1; ax : in signed(w-1 downto 0); bx : in signed(w-1 downto 0); cx : out SIGNED(2*w-1 downto 0) ); end test1; architecture rtl of test1 is type ar18 is array(0 to n-1) of signed(w-1 downto 0); type ar36 is array(0 to n-1) of signed(2*w-1 downto 0); signal ar : ar18; signal br : ar18; signal cr : ar36; begin process (clk) begin if rising_edge(clk) then for i in 0 to n-1 loop cr(i) <= ar(i)*br(i); if i = sel then ar(i) <= ax; br(i) <= bx; cx <= cr(i); end if; end loop; end if; end process; end rtl
