9 years agoSingle multiplier takes up a whole DSP block for
Hello, I'm using a Cyclone V SOC FPGA. Currently my design has 8 multipliers (which I coded in VHDL instead of instantiating). The inputs to the multipliers are 12 and 16 bits wide. ...
9 years agoAccording to my observation, Quartus uses all available DSP block before it starts packing multipliers. See same-topic discussion at Edaboard
http://www.edaboard.com/showthread.php?t=368754 I managed to fill up all 25 DSP blocks of Cyclone5 A2 with this testlibrary IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity test1 is
generic(
n : integer := 50;
w : integer := 18
port(
clk : in STD_LOGIC;
sel : in integer range 0 to n-1;
ax : in signed(w-1 downto 0);
bx : in signed(w-1 downto 0);
cx : out SIGNED(2*w-1 downto 0)
end test1;
architecture rtl of test1 is
type ar18 is array(0 to n-1) of signed(w-1 downto 0);
type ar36 is array(0 to n-1) of signed(2*w-1 downto 0);
signal ar : ar18;
signal br : ar18;
signal cr : ar36;
begin
process (clk)
begin
if rising_edge(clk) then
for i in 0 to n-1 loop
cr(i) <= ar(i)*br(i);
if i = sel then
ar(i) <= ax;
br(i) <= bx;
cx <= cr(i);
end if;
end loop;
end if;
end process;
end rtl;
